4th gen door panel speaker pods
Old 06-13-2002 | 12:31 PM
91L98Z28's Avatar
Car: Z28
Anyone know if the indicated part of this door panel is removable as a seperate piece, and could then be attached to a 3rd gen door panel??
Old 06-13-2002 | 02:44 PM
91z4me's Avatar
You could cut the peice out but otherwise it is a part of the door panel.
Old 06-13-2002 | 04:26 PM
logikal6785's Avatar
why don't you put in the whole door panel ? they're direct-fit bolt in except for a little gap at the top sill
Old 06-13-2002 | 05:21 PM
91L98Z28's Avatar
Car: Z28
well, i have a camaro not a firebird, and everything i've read says they are in no way a direct bolt in.
Old 06-13-2002 | 06:08 PM
look at this conversion job .... i wish i had the time to do the dash that he did too
http://www.fortunecity.com/silversto...h/63/index.htm
Old 06-13-2002 | 06:10 PM
http://www.fortunecity.com/silversto...ch/63/id16.htm
"alot of people have asked about this, you can see if you swap just the door panels then they hit the old dash, you can see the new dash has a grove in it to account for this"
i will just mount a tach there and cut off the nub at the top =D
Old 06-15-2002 | 07:21 AM
jobryan26's Avatar
Re: 4th gen door panel speaker pods
Yes it is and it's available through Year One They are called "Map Pockets" and the ones with the 2 speaker grills for the UW2 10-speaker system runs $59.95ea. Part numbers are:
MP27-Drivers side
MP26-Passenger side
As far as how they mount, contact DJ Sexay in the car audio forum because he has a late model Firehawk and he's had his apart. Good luck.
John
Frozer!!!
01-19-2024 05:55 PM
IROCZDAVE (88-L98)
10-06-2016 10:08 AM
Out-Cast
08-23-2015 07:33 AM
89lsc
08-14-2015 05:58 PM
Quick Reply: 4th gen door panel speaker pods
