Camaro gfx
Camaro gfx
I searched the boards but i couldn't find an answer...
I'm putting ground effects on my firebird, and i had IROC bumper cover and learned the hard way that it didnt fit, but here my question;
Will the ground effects off the camaro that go on the quarter panel between the bumper cover and the rear wheel match up with a trans am bumper cover? thanks.
The only GFX you can use to go in between the firebird and camaro are the door and rocker GFX. If you tried the lower rear quarter ones they wouldn't line up with the firebird back bumper because they weren't designed for each other .
For future reference, doors from either 82-92 camaro or firebird can be used on any thirdgen (although internals change depending on year). But front fenders, hood, front bumper and rear bumper can only be used on a camaro as the firebird has different body parts ( unless you are changing the front over, which doesn't make much sense seeing as the firebird has different fender flaring compared to the camaro).
I hope this helps, Dave.
