coolant temperature sensor
hey, i need to replace one of my coolant temperature sensor, i nee to replace the on on the manifold. does anyone have any pics or diagrams or advice at all? let me know. thanks.
Dozer80464@aol.com
Dozer80464@aol.com
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The coolant sensor on the TPI (and TBI if I'm not mistaken) intake manifold is for the ECM. Most had a yellow & a black wire with a weatherpack connector.
Unscrew the old one,, screw in the new.. it's failry straightforward. Most new sensors come with a sealer on the threads as well so don't wrap teflon tape around it because it will 'insulate' it causing a 'false' (usually low) reading.
MCamaro is right tho.. there are specific forums for this question.
