seat recliner thingy
heres the deal, i bought my car with the seat like stuck in "pimp-daddy" position. Right now the car just gets moved in the driveway, but when i finally finish it, i won't be able to drive like that. I have a parts car with a recliner thing that works. how can i switch 'em without switching seats? BTW, good car is 88 formula, parts is 84 6 banger, in case they might not swap
reclining mechanism is bolted onto both the top and bottom seat frame using 4 bolts. slide the seat covers back a little bit to access the bolts.
also, check out http://www.geocities.com/modularmotor/thirdgen/seatswap for some other thirdgen seat related information.
1 Post
Car: 89 RS
Transmission: TH350
Like 2VModular said, or you can do what I do. Just put the drivers side backseat down, and put a basketball inbetween the folding part and the bottom seat, works great.
I need some 4th gen seats bad.
1 Post
Car: 89 RS
Transmission: TH350
Yeah, the B-Ball works good.LOL But actually my recliner still works, but the left side rail underneath broke in half. So I either have to pull the seat and weld it back together then fix the horrible rip in the seat, or just get some new seats. I can live with it now, but sooner or later I'll get some 4th Gen seats.
recliner is an L-shaped device, two bolts hold each leg of the recliner to the seat frame. top portion is a little bit longer than the bottom, but neither extend the entire length of the seat. can gain access to all the retaining bolts by sliding the seat covers off a little bit. may have to remove some "hog rings" to avoid tearing the seat cover. eastwood company has hog rings & hog ring pliers forsale inexpensively.
note: seat recliner is not usually the cause of the seat leaning back too much. is usually caused by a bent or broken metal seat frame. you will likely be able to make one good seat out of your two sets since it appears that you have one with a good frame but wornout upholstery, and one with a bad frame but good upholstery.
the seat doesn't recline or adjust that way at all it doesn't seem like it would be broken. i might just wait on buying some 4th gen seats, just got a higher paying job =)
i just happin to see this post.....
MAYBE THIS WILL HELP SOME OF YOU!!! i hope....
same thing happin to me {"pimp position"}
"mabe this is norm for 3rd gen's" i dont no "
the seat just broke after i got in" not fat thanks for ask'n "
so i went home my "dad said to put some 12 packs behind it"
THE HELL WITH that i look around and just tryed puting it up and down
i removed the plasctec and i watched it. as i moved the seat up and down i saw a slot in the steel
so i just put a bolt there and it worked the steel just rested on the bolt
and no more gay pimp seat"
{as seen in pic}
{as seen in pic}
{as seen in pic}
{as seen in pic}
Re: seat recliner thingy
my seat folds foward without hitting the switch so i bought a new seat recliner, you can still get them, just did a test fit and it works fantastic now, it doesnt snag anything to take it off by the way.
