Under Hood Insulation?
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Do you need the under hood insulation or can you take it out with no worries?
Andrew
Andrew
Car: '97 Z28
Engine: 5.7
Transmission: M6
Took mine off 10,000 miles ago. No problems. Maybe a little more engine noise noticable (GOOD THING!), no dust raining down on engine compartment, probably cools a little better too.
Car: www.hrfbody.com
Engine: www.hrfbody.com
You can remove it, but don't overheat to much, some might say it will cause your hood paint to dull but I say no more than direct sunlight does anyhow.
big benefit to hood insulation is the interior of the car is quieter. some vehicles, such as my crown vic police interceptor don't come with any hood insulation installed from the factory.
if it bothers you, dynamat makes hood insulation that deadens noise better than the general motors original equipment insulation does.
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
88, carburetor, compartment, cool, crown, engine, hood, insulation, overheating, point, remove, removing, underhood, vic, victoria, z28
