paintless dent repair?
1 Post
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
It's a process of using special rods that gently massage the dent out from the inside of the panel. Only trained people should attempt this. A mobile company in my area charges $65 per panel. Only pushed in dents like door dings or if you hit your car with your fist can be taken out.
Car: 91 Z28 Convertible
Engine: 305TPI
Originally posted by GKK
... Only pushed in dents like door dings or if you hit your car with your fist can be taken out.
ever heard of the twist-a-dent? My stepdad ordered one, we just got it in but haven't gave it a try yet. It works by fastening a suction cup with a hot glue type substance to the dent, then attaching the tool to it, and turning the ****. it works kinda like a gear puller/flywheel puller for small gass engines. i'll fill you in if it works.
Engine: 305TPI
someone just posted about the twist a dent thing. It says it removes the dent portion but still leaves a ripple effects where the metal was stress. Metal isnt quite like a platic bottle that will bounce back perfectly.
