parking lamp waxing
parking lamp waxing
hey
i was wondering how i can get my parking lamps to be really clear again...i dont know how to remove the casing from the light, or the plastic front...
and i have seen black outs for them and stuff...i was wondering if i got a plastic cover for it and put like 8% limo tint on the plastic, would that make a good parking lamp blackout?
thanks
mike
thanks
mike
I've had excellent luck sanding and buffing them out. They look almost brand new and it even gets rid of a lot of the yellowish tint that they aquire.
Tint wouldn't stick very well to the plastic, especially with the raised letters that are molded into the lens. And it wouldn't last very long out in the elements.
You can also use an aluminum/plastic polish or a fine cut rubbing compound - then wax them afterwards. As for tinting them, you can use the Niteshade paint or hit your local hobby shop and get translucent black paint (or red, blue, etc).
Steve
Steve
1 Post
Car: 1992 RS
Engine: 406 Stealth Ram
Tinting the outside of the lens probably isnt the best idea. I guarantee that whatever coating you put on it will be sandblasted off in a matter of weeks. Maybe a coating of that nightshade paint on the inside of the lens would work better? You'll have to cut it open and re-glue it though, because the glue that GM uses is NOT coming apart
Why and how would it be sandblasted off in a couple of weeks??
If you Nigthshade the outside of the lens it will stay put and last forever. Haven't you seen my tail lights?
1 Post
Car: 1992 RS
But, not only will it last longer if the inside of the lens is tinted, it will look better. If the tint's on the outside it has that "obviously painted" look to it. If it's on the inside it just looks like the lens is darkened (like it should look).
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Here is my post about this from a few months ago. It has pics inside.
https://www.thirdgen.org/techbb2/sho...threadid=87154
Originally posted by Jza
:sillylol: That's the funniest statement I've ever seen. Do you drive backwards a lot? (rib)
1 Post
Car: 1992 RS
Not to burst your smart *** bubbles, but there are several members on this board with nightshade on the parking lamps without a problem.
RedLeader289
05-28-2019 01:47 PM
