Inner fenderwell....
Does anyone know if there's any aftermarket companies that make an inner fenderwell for the front driver side, cause I got a rust hole about the size of a tennis ball at the top of the water tank and at the bottom. If they don't, any way of fixing this real good?
you're not alone with rust holes in this area, are many other thirdgens with the same problem.
most bodyshops would just weld a metal patch panel to fix. replacing the entire strut tower is usually reserved for collision work and would be prohibitively expensive.
I have a friend of mine that can weld really good and said he could mig weld some pieces in and make it look like new, but I would rather have a new piece in there if they make that part, which I don't think they do, cause I can't find it anywhere.
