92 rear hatch wiring diagram
Anybody have a wiring diagram for 92RS rear hatch? Mine won't open from the switch. When I pop it open with the key, of course the motor doesn't rise. If I unplug the motor and plug it back in, on the 3rd or 4th try the motor cycles up and I can close the hatch normally. I'm thinking that either the motor is positioned too low(if it's even adjustable for heighth) or the switch on the latch is bad. When I unplug and reconnect the switch, I can hear a clicking. It seems to be coming from what appears to be a relay. Thanks for any help. I don't have a manual yet.I'm saving $$$ because I just bought the car. Need a couple weeks of recovery. Can you suggest a good manual other than GM's overpriced edition?
