Puddle on Air Filter
Old 04-30-2002 | 02:20 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I have an '83 T/A with the stock bubble hood. I've noticed that after it rains, there's a small puddle on my air filter assembly. Has anybody else run into this problem?
Old 05-13-2002 | 12:28 AM
z28esser's Avatar
It's a common problem with that year.GM had a recall on it in fact.They got a new hood,most of the cars didn't go in for the recall until someone tried to start it after a rain storm and hydrau locked the engine and bent half the rods.I believe the replacement hoods didn't have a functioning scoop.
Old 05-13-2002 | 09:10 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have a drin rail that drips between my steering column and my exaust manifold under my opening on my bird that I got from an 83 T/A
John
Old 05-13-2002 | 05:05 PM
83T/A_Dave's Avatar
my 83 does the exact same thing. I checked the air cleaner and it appears that no water is getting in, it just leaves a puddle on top of the air cleaner.
okfoz, do you have a pic of that rail so I know what your talking about, thanks.
Dave
testing sig...
Old 05-13-2002 | 07:10 PM
83T/A_Dave's Avatar
okfoz, was it you who created the font you used on your webpage? if so, could you please e-mail me the font? I need it for a drawing I'm working on.
Old 05-14-2002 | 07:20 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Like 83T/A_Dave, the water doesn't leak inside my air filter either. It just sits there, and I don't want it to screw up the paint or possibly the motor....I guess the easiest fix is to buy a garage...although i'd also like to take a peek at that drain rail okfoz!
Old 05-14-2002 | 09:00 AM
okfoz's Avatar
yes, it was me with the font, I can e-mail it to you, just don't share it.
As for the drain, I don't have any pix right now, give me a chance to take some pix of it, I might be able to get them up tonight.
John
Old 05-14-2002 | 09:29 AM
darbleinad's Avatar
Car: 84 Trans Am
My 84 T/A does the same thing. the water doesnt seem to get into the air cleaner, but it is sure annoying soaking it up everytime i want to drive after it rains. i am looking for a solution to the problem.
Old 05-14-2002 | 11:32 AM
okfoz's Avatar
here is the troff I am talking about, unfortunately I have removed it from my car because I installed TPI.
John
Old 05-14-2002 | 03:31 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
I've run into the same problem....however I think on my hood the entire "grill" area has a gap in it that runs water straight onto the engine.
I saw a site were a guy siliconed the entire seam. I may be doing the same thing soon.
I got this hood from an 84 trans am. Ive also since fixed the broken light problem and installed grid Tailights from an 85 t/a. Ive got new doors going on next plus the 82 ta front ground fx.
Old 05-14-2002 | 04:02 PM
83T/A_Dave's Avatar
John,
I would greatly appreciate If you could send the font, Please E-mail me
I just need it for some drawings and 3d models I'm working on, thanks.
Dave
Old 05-14-2002 | 06:01 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I could swear your car is winking at me...
Old 05-14-2002 | 06:02 PM
darbleinad's Avatar
Car: 84 Trans Am
i have that through, but mine still leaks.
Old 05-15-2002 | 10:06 AM
okfoz's Avatar
When I had the Ram air setup I never had a problem, of course I don't drive the car in the rain so that might explain some.
John
1992 Trans Am
05-10-2023 08:19 PM
specialized
06-18-2022 10:26 AM
Brinkkl2000
08-04-2018 09:29 AM
Thornburg
09-01-2015 04:39 AM
Quick Reply: Puddle on Air Filter
