Has anyone rebuilt their seats and added better side to side support?
Old 04-30-2002 | 08:24 AM
bigman's Avatar
Basically, I don't want to pay $400/seat for new seats, but the stockers don't have big enough side bolsters and I have to spend have of my concentration and energy while driving fast trying to stay put in the seats. So, I thought about yanking the seat covers off, and welding some side bolster wire frames, padding them with closed cell foam, cutting out new fabric on the pattern of the old fabric, sewing it together, and recovering the new improved seats. Anyone, anyone? Bueller?
Dan
Old 04-30-2002 | 08:26 AM
bigman's Avatar
That should be half of my concentration.
Dan
Old 05-01-2002 | 08:24 PM
2vmodular's Avatar
look around the salvage yards. most gm "n-body" bucket seats will bolt in if you use the stock f-body seat tracks. any 1982-2002 camaro/firebird seat will also fit.
https://www.thirdgen.org/techbb2/sho...hreadid=101074
Old 05-01-2002 | 08:38 PM
orange rocket's Avatar
How about the 4th gen T/A seats? My 00 has em and with the adjustable bolsters is definetly a plus. I say get some 4th gen T/A seats
Old 05-01-2002 | 08:48 PM
Blue502's Avatar
I had my front seats reupholstered back in '94 on my '86, and when I did it I had them use the old covers for a pattern which created a slightly larger cover than original due to stretching over the years. Then I had them install the new covers with extra stuffing. They look absolutely stock, but are definately more comfortable than stock, and have better lateral support. The seats rub against the center console due to the overstuffing, but that doesn't hurt anything.
Old 05-01-2002 | 09:57 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Lance, were they able to get a matching fabric? The reason I ask is the seats in my 84 are faded, and I don't think the fabric is made anymore.
I've attached a picture to show my driver's seat.
Old 05-02-2002 | 08:32 AM
bigman's Avatar
Thanks for the replies, that's something I didn't know, that the 4th gen seats have adjustable bolsters. I'll look into that more.
Dan
Old 05-02-2002 | 10:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Another consideration is the Lear/Seigler Conteur seat, which was an option in early to mid 80's Camaros. The driver's seat has adjustable bolsters, not only on the back but also on the seat cushion. Moreover, there are lumbar and thigh adjustments. Mine sits on a six-way electric track, so the number of adjustments are numerous.
JamesC
Old 05-02-2002 | 01:24 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Ultima seats, often called GTA seats also have the side bolsters, that are adjustable...
John
Old 05-02-2002 | 02:48 PM
un4givin89's Avatar
My *** isn't fat and I'm not over wieght, so this isn't a problem for me, my seats are very comfy and support me at high speeds very well.
Old 05-02-2002 | 03:06 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
just a word of advice, the thirdgen seats are more comfortable than fourth, even in leather... Never heard any info as to how well the lumbar or adjustable bolsters work...
Old 05-02-2002 | 03:25 PM
83 Crossfire TA's Avatar
I did something similar with my ’83 when I was autox’ing it. I’ve got a fairly narrow butt for someone my size and got tired of tieing the seatbelt in a knot and sinching it down to keep me in my seat.
I took the cover off the seat bottom, and conveniently found that the pieces of ½ inch particle board that were left over from making cutouts for 6x9 speakers were just about perfect. I took 2 of them, rounded the outside edges and attached them to the inside of the frame for the lower side bolsters and then forced the padding back over that and put the cover back on with some hog rings. Couldn’t have worked better. It also made it impossible for my wife to sit in the seat without actually sitting across the bolsters
Old 05-02-2002 | 04:13 PM
bigman's Avatar
Now, that's info I can use. The car is mine, the van is hers. Besides, I've got 8 inches and a hundred pounds on her, I don't think it'll be a problem.
Dan
Old 05-02-2002 | 04:41 PM
2vmodular's Avatar
take a look at the olds achieva seats, the bolsters are nonadjustable but are a considerably thicker than the stock f-body ones.
Old 05-02-2002 | 04:45 PM
All I can say is I had had my share of third gens and driven in countless others. My 00 T/A absolutly killed me for about the first week driving in it. But finally after playing with the seat all the tim eit is perfeect. I have done 6 1500mi trips in it non stop and could hardly call them uncomfortable. Even my mother boyfriend said it was better then my mothers SL 500. So how bad can they be? If they are adjusted wrong you will swear up and down how ****ty they are but when adjusted you will love them. As for lumbar and articulating sides they work perfectly and I have no complaints. The lumbar is about as comfortable as my Eldorado.
Old 05-03-2002 | 03:47 AM
johnyIROC's Avatar
I agree. I went from bogus '83 Z28 seats to '95 leather TA seats. The fourth gen TA seats own all other seats. You can adjust the bolsters until they are pinching you in. They are by far more comfortable than my old seats. The only reason why people find them uncomfortable is because as soon as they get them they set the lumbar to max. I almost never use the lumbar support, and most people don't need to. With the lumbar turned off, these are the most comfortable seats by far.
At work I actually go outside and take my breaks in my car because my seats are so comfortable.
Old 05-03-2002 | 01:03 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
That's not a personal attack is it? Maybe bigman is like me, I am 6'3" and 250, but not fat!
Mark
Old 05-03-2002 | 01:26 PM
Blue502's Avatar
Any upholstery shop worth anything should be able to get your fabric. But since it isn't being made anymore, the price will just keep going up over time. I can still get original fabric for my '63 Nova, but the price has got to be astronomical, it was the last time I checked (glad I bought a complete roll back around '81 or so).
The point is, you should be able to get the materials, but you may be hard pressed to get the fabric and get the new covers made for under $400 per seat. You might consider getting the fabric now, and have the covers made later.
Old 05-03-2002 | 03:04 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
These babies do me just fine. There is no equal
:hail: :hail: :hail: :hail:
Attached Thumbnails Has anyone rebuilt their seats and added better side to side support?-inside.jpg
Old 05-03-2002 | 10:58 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
WTF are those? Those are slick!!!!
Old 05-03-2002 | 11:43 PM
cort351w's Avatar
Mark
I'm 6'1 and 180 right now. My goal (until I reach it and set another) is 200. I'm very cut, though, and plan on staying that way so it may take me a while to get up there. I wish I was 250 without fat .
Old 05-04-2002 | 03:37 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Thoes are Recaros.
Fu*king Bad *** seatssssss.....
Old 05-04-2002 | 09:33 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Whenever I looked on the recaro site, all the seats were fugly, i would have remember good seats like that
Old 05-04-2002 | 10:54 AM
okfoz's Avatar
there Recaro Seats, trust us, I have seen them in junk yards. the little emblem in the middle of the seatbacks, if you look really close reads RECARO
John
Old 05-04-2002 | 01:47 PM
85 T/A WS6's Avatar
stuart,
Pontiac first used the Recaro's in the 1981 T/A NASCAR pace car.
In 3rd gens the can be found in the 1982 Recaro Edition as cloth.
There are in the Daytona pace car in 83 and the 83 Recaro Edition
as leather.
In 1984 they were in the Recaro Edition and the 15th Anniversary Trans Ams, again as leather
In 85 the Recaro Edition was dropped but the seats (RPO AS5) could be added as an option. This version is cloth. The option lasted until 1986.
The cloth is not very durable so thats why you dont see many left.
Hope this helps !
Don
Attached Thumbnails Has anyone rebuilt their seats and added better side to side support?-recaro-tag.jpg
Old 05-04-2002 | 03:44 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
ahh, they were offered on our cars too, thats cool. I believed you, just didn't see it on here site, I will have to check again. I have read the White book and Red Book and since they didnt have pics of the seats, I never knew what they were talking about. I wonder if they say they were Recaro, i will check when I get home to my books...
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
Mister_Johnny99
Interior Parts Wanted
08-14-2015 12:59 PM
BlackBoulder
08-11-2015 11:15 PM
novaderrik
08-10-2015 12:44 PM
Quick Reply: Has anyone rebuilt their seats and added better side to side support?
