plastic piece in headliner for seatbelt
The tabs that hold this piece up broke off on the passanger side. I got a perfect one at a junk yard. Just wanted some help on how to get the new piece on. I don't mind cutting off the old one, but I would like to keep the new one as nice as possible.
check with hawks or year one. they make a replacement for this kind of situation that already has a slit.
give cytting it a try right between the 2 tabs that broke. IIRC thats where the ones i seen that were factory split were cut. BTW, make the cut on the backside on the sail panel side.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
i had the same peoblem. What i did was I filed a small slit so the belt could pass. Barely noticeable and fits great!
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
got mine off ebay factory gm with slits in them not noticable once installed. they were like 10 or 15 bucks also
Engine: 3.4 / 5.0
looks good! I actually cut mine on the other side (the right part on the pic) but it should hold up with no problems
gta892000
09-16-2015 12:37 AM
