my tires rub
my tires rub
Just put my cragar ss 15" with bf goorcih radial ta 245/60/15's on today and my front tires rub a little in the front on turns ( on the back of the wheel well toward the doors)..I havnt checked it out to much.but i think its the rubber protective piece that goes inside the wheel well.. ANyone else had this happen or any other ideas who to fix thanks
Aj
Aj
I've got a similar prob. Hopefully I'll be getting some more answers over in the suspension and brake forum. Heres a link to what I've got so far
https://www.thirdgen.org/techbb2/sho...5&goto=newpost
Car: 3 3rd Gen F-bodies and 7 others
Engine: 305 CFI, 350 TPI & 3.8 Turbo V-6
Transmission: all automatics (stock)
Uh, SMALLER Front Tires!!!!
245/60R15's are a bit too BIG.
Or you could go the Cheaper way and buy different wheels with a different offset.
Seriously, for 15" wheels, A P235/60R15 is plenty wide for staying with a 60 sidewall height.
1 Post
Car: 89 RS
Transmission: TH350
I used to rub with the 225/ 60 / 16's (yuk! It's what the previous owner had.) I switched to 225/ 50 / 16's and have had no problem. Now the Potenza Re910 tires I have on the front are much shorter than the old ?60's I had on there.
I think your tire is too wide and too tall, not anything to do with the rim.
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
First of all Ghey Boi chill out, no need for that sort of stuff around here. People like what they like, keep your pointless opinions to yourself.
Secondly, I'm running 255/50/zr16's all around on my 16x8 Iroc rims and my fronts don't rub but the rears do on really hard cornering. They also do it pretty bad when powersliding a corner which doesn't make sence to me because if the rear tires are spinning the weight of the car shouldn't roll quite as bad causing the suspension to compress and the tires to rub, but who knows. I'd really like to know how to stop this from happening. It is really annoying.
Ryan
Ryan
fixed most or problem
Well i cut away the rubber wheel well protector and then pounded back this little piece of sheet metal above the gfx's. Should be ok now..i think i need an alignment now..how much do they usallly cost and price
thanks
Aj
thanks
Aj
No way, that's insane, yall must do those print outs and stuff, atleast I would hope you get more for that. Seriously though, last time I got mine aligned, and just aligned it was like 20 or 30. I don't know what the difference is.....
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
