Painting; Sand or Not Between Coats
I'm a guitarist,.....not a painter.
After the primer & all, do I sand between coats or just layer on the coats?
The hall has me on vacation for 4 months now & after a couple of spray cans of this black acrylic lacquer right over the Van Nuys quality, clear coat peelin', (it does look alot better, it was that bad),
I'm a little surprised of my technique & now, bordom has set in & I get thinking, "if I sand down the peelin', primer",.........
I don't care if Maco can do a better job, I've got gear to buy!!!
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I heard sanding between coats is the best.. I think it makes the paint stick better also.
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
