4th Gen Camaro Center Console in 3rd Gen?
1 Post
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I've seen the posts on this being done in Firebirds and TA's. Some of them mentioned it being harder in Camaros. Why?
I'm installing a T56 and will have my center console out anyways-I'm not hating on 3rd gen c consoles, just like the idea of the 4th gen console in there.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Reason is the style of the Camaro console and the firebird console.
The Firebirds' radio pod is up a little higher and is seperate from the console. The camaro console looks looks like the pod is attached.
Maybe if you got a Firebird pod and 4th gen console it would fit easier.
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Will the Firebird pod(82-92) bolt into the camaro?
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I think you would have to use the entire 3rdgen Firebird dash and radio pod along with the 4thgen center console. The Camaro radio pod and climate controls are attached to the console and the firebird pod mounts in a different position. The Firebird radio pod might mount to the Camaro dash, but I've never seen it done. Does anyone know?
Car: 1986 IROC
Engine: 305 going to 355
Mark
Transmission: auto
dash
I know the radio pod in the Bird is bolted to the lower part of the dash by 2 10MM bolts--I don't think the camaro dash has those provisions for the radio pod.
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Someone who's already successfully done this conversion ought to write a tech article detailing the parts needed. I keep hearing of a 4th gen console in a thridgen but nobody ever mentions whether the console came out of a 'bird or a Camaro. I wanna install a new console in my car too but i would like to know which console and pod to buy before i hit the wrecking yards. No point in senselssly buying stuff that i won't be able to use.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
