How good donor car is 94 Firebid
Car: 91 Camaro RS
Axle/Gears: 4th gen rear
Have someone used or know is it good choice or not to use 94 firebid as a dor car for 91 Camaro? It has 5,7 lt1 and manualt T56. Does the engine mounts are the same as Camaro or not and how much of drivetrain, brakes and other stuff i can use.
Thanks for Your replies!
Re: How good donor car is 94 Firebid
Here is information on swapping a LT1 into a Thirdgen:
https://www.thirdgen.org/forums/ltx-...questions.html
You can use the entire rear axle assembly, but it will push your wheels out if you are keeping the stock rims. For front brakes, I don't know of anyone going to the hassle of using them since they aren't the improvement the 98+ brakes are.
You can use the seats and other misc interior parts if you need them.
Ghettobird52
07-05-2024 11:18 PM
Linson
08-21-2015 02:12 PM
db057
08-11-2015 10:11 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
