Options for front turn signals
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
Re: Options for front turn signals
careful if you go full LED, the front turn signals basically control the flashing of the turn signals and the voltage across the side marker lamps. Even with the correct turn signal relay in the convenience center under the dash, you will need to work on the wiring. So my car has full LED's minus the front turn signal/driving lights.
You will need to use a relay for each turn indicator, post 10 & vid @ 6.
https://www.thirdgen.org/forums/auto...t-markers.html
