Anyone here Plasti-dip 'in ???
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
big sight about it, dip your car.
see these high end cars on the sight, with a if you don't like it, just peel it off dip job done to the whole thing. Some do look really nice with the soft mute colors and mixes.
But I keep reading, if you don't like it, you just peel it off.
would it not self peel with time then, if it can just peel off. Wind at speed get under it just a little and???????
Some of them cars look nice but my stuff is really driven.
outside year round, sun, rain, ice, hot, cold, salt, sand, dirt, mud
Re: Anyone here Plasti-dip 'in ???
Check out the plastidip thread.
Not many here are REALLY experimenting with this stuff. There are so many cool colors and options these days.
This is a good example of why dip is awesome. I bought and 82 SMC hood. Factory look plus weight savings. So I was all for it. The paint on it was in terrible shape, though. The clearcoat was toast.
So I threw black plastidip on it.
Then I decided I would plastidip myself some black headlight buckets...
Then I found out the 82 cars got single stage paint, so I peeled all of it off (dont get me wrong, it took a little while, but mainly because it was on the car for nearly 2 years and it was way too thin because I didnt realize you needed 5-7 coats for easy peeling. I ended up spraying more dip on the hood to get it off and as soon as I figured out that every layer I added made it easier to remove, I progressed pretty quickly with it) and polished up the hood. Try doing that with flat black paint. The hood would have stayed flat black forever. Thanks to plastidip, I had a second chance.
Then I got new wheels and dipped those, and dipped the inserts in the hood. Wheels are anthracite gray dip with pearlizer sprayed over them.
I love this stuff.
I also use it as easy waterproofing/undercoating on things. It doesnt come off unless you want it to.
I love this stuff.
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
I've had plasti dip on my jeep since the stuff first came out ( they only had black at the time ) the stuff works good and does not peel off at highway speed. It holds up well in rain,snow,Ice, mud rivers ,forests and stuff...
....But this might help ya abit....
https://www.thirdgen.org/forums/auto...ip-thread.html
Considering this if I don't paint the car this summer... No idea what to do for colour.
Car: camaro
Engine: 3.1
Transmission: auto
i've had horrible experiences with the stuff. I did the lip, hatch deck, and Ttops on my camaro. its very easy and forgiving for the spraying and looks good for a couple weeks, then it starts fading and is a lot of up keep to keep it looking fresh. also a couple birds pooped on the Ttops and rear and it ate through it (to be fair I didn't clean it up for a couple days). maybe there are radioactive birds here in so cal but im just sharing my experience.
I know im gonna get people that say I used it wrong but I followed the instructional videos on how to use the product and put about 5-6 layers on and still had these issues. it probably holds up a lot better if you park your car in a garage but im not that fortunate, it sits in the direct sunlight and cali heat. maybe some1 else can share their experience with the product
Weird, those pictures of my car with the hood dipped, car was parked outside at my apartment in the Georgia summer/heat for over a year like that and it may have faded a little but I never noticed. my headlight buckets have been dipped for at least two years now too, no fading. This stuff is far more fade resistant than flat black paint. I find it really strange you had issues with it. I never thought it was a lot of upkeep either... in fact I'd usually just hose it off and call it good.
1 Post
Car: 1991 GTA
Engine: LB9
I dipped a '91 Camaro over the winter.
It will hold up fine to daily driving, wind at freeway speed is not going to peel it off.
A few high traffic areas like a long the top of the ground effect where you get out of the car have started to peel, but it will be an easy matter to touch it up.
It does hold dirt like a magnet, so you do have to be careful about how you wash it.
Dipping a whole car is not exactly cheap. Four gallons and a spray gun run about $400.00 bucks.
So while you can peel it off if you don't like it, you will flush a substantial(to me anyway) amount of money in doing that.
Car: camaro
Engine: 3.1
Transmission: auto
I think most of the guys who dislike this stuff have clearly NEVER used it. It's cheaper than wrap and it's fixable when it's damaged and allows you do DIY a lot of this stuff on your own. The sky is the limit as far as what you can do with all the things that are available today with all the additives and colors and finish variations you can achieve with it. Plus it actually protects your paint while it's on.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Cost a bit to much if you ask me, should be half or less for something you peel off.
I can buy old school paint for $35gal, and paint my car 3 times. open any old hotrod mag and tell me old school paint looks bad.............
1 Post
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Problem with plasti dip is for every one job that's done well, you have 10 that look like ****. Like this..
1 Post
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Agree spray with the sprayer and mine has been dipped for about a year and a half now. No peeling and easy to keep clean. Mine is a daily driver as well
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
Last I looked into it they have a ton of colors now. Pearls, metallics, etc. I think they going statement was it cost about $400 to paint an entire car correctly with Plasti-Dip.
I thought about it for a while before I painted my car, would never do it now.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Rocky's car was voted one of the Top 5 cars at last year's third Gen roundup, and came THIS close to winning again this year. that award is voted on by all third gen owners in attendance, and is the ultimate sign of Peer respect. His car is even better looking in person than in photos, and that's saying something
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
Ive been experimenting with it...black with the glossifier...i found out that if you use some turtle wax polish on it then go back and wax it...smooth as glass and will not collect dust like it did originally...in fact it feels and looks more like paint...
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I played with some flexy dip made by rust-oleum today..In was in rattle cans..bought 2 cans of black...about $8. a can..I did the grill which is normally gray on my year Escalade and the Chrome on the luggage rack..I'm going to get another can and do the chrome on the running bords...This is the first time I have used it...it's very forgiving. .I had a run on the grill ..I wiped it with a paper towel...back down the gray. .then built it back up with light coats...it's not perfect. .but it's better then looking at a gray grill on a all black truck..
I did my wheels a couple years ago, been holding up pretty well so far.
I might try a different color, getting tired of black. That's what so great about this stuff, you just peel it off and try something new.
Car: 1983 Camaro, 2000 Impreza
Engine: 327, 2.2L
Transmission: T5, 4EAT
Just dipped this weekend. Have friends with grills/bumpers dipped and it has been holding up great. Shall see how this holds up to baking in the sun all day.
looks awesome!!! i love that blue!!!! i had some paint bubbling on my headlight pockets, so i sanded and plasti dipped them. came out good. i'll post pics tomorrow.
BlueZee28
11-18-2011 12:49 PM
