40 LED front Markers
Started with a ebay special from china, 48 LEDs per, too big to fit.So gonna lop off 2 rows, so its 40 LED.Board w/relay & 1157 base a 150ohm resistor (yellow heatshrink) on the relay.So they'll blink bright/normal w/the lights, but bright/off w/out the running lights.
Installed in housing & lit, relay will be mounted inside lamp.No hacking of the stock harness.Plug & play all the way.
Not sure if i like this look or w/ stock diffuser.
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: 40 LED front Markers
Sweeet thread man. How did you wire it all tho and where did you get the socket to plug into the original light socket?
Here's a schematic i made for the side markers, its the same for driving lamps.The blu & brn wires are the same blu-brn on the fr. markers.Only difference is fr marker uses 3 wires.Third being neg, which in this case goes to 86 on the relay.The socket is just from a 1157 bulb.
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
Did you also modify your side marker light as LED to work with the front marker lights?
brian89transam
09-25-2002 08:15 AM
94-6spd
11-14-2001 03:07 AM
