255/50r16 rear tires
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: 255/50r16 rear tires
A 255 50 16 will be half an inch taller and half an inch wider than stock 245 50 16 tires. If you really don't want it to look like a trailer park racer then use tires with the same height on all 4 wheels.
Car: 1990 Firebird
Engine: 350 TBI
Why go through all the trouble of switching from a 245 to a 255? I doubt there will be much (if any) difference in handling. If you want to run wider tires you are going to have to get wider wheels.
Car: 1991 Formula 350
Engine: 350 TPI (L98)
Axle/Gears: 3.23 Posi
I have 255/50 R16 all way around on stock wheels. 255's rubs front sometimes. Basically every time you turn your wheels to the max
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
255/50r16s with your existing fronts are as large as you will want to go. If you jump to 275s that's probably the look your trying to avoid.I think it depend on your car,wheels,what stance/rake you have or want.
A photo of your ride would help. Sweating over a half in though I seriously doubt it will make you look white trash, or whatever.
Photo please.
Photo please.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Photo please.
Photo please.
Transmission: Pro-built 700R4
I'm currently running the 245's up front with the 255's in the reat and as JeremyNYR said, it is not noticeable at all.
thanks guys, i didnt realize it would be such a minute difference. and the reason why i am contemplating different tire sizes is cuz my rears are shot....or probably were last year, before the burnouts. now i have two slicks as rear tires, the fronts are fine, look brand new still. and anyone with rear drums knows that the rims arent interchangeable so i dont have that option. and after switching my rear to 3.73 (and changing the vss to accomodate as closely as possible to the gear change) my speedo is still off a bit. Thought slightly larger tires may help.
Either way, i'm due for rear tires, and i was weighing my options. since you guys have pointed out how hard it is to tell the difference, i'll probably go with the 255's. thanks guys
Engine: TBI,5.0
Do you have two threads going on this subject now ?
https://www.thirdgen.org/forums/whee...elp-tires.html
this subject is in regards to photos of how this tire size would look. that subject was in regards to handling and increasing tire size. if you consider the separate subjects one in the same then yes, i have duplicate subjects to the same reference
Engine: TBI,5.0
No big deal man,I just did not catch on,a little slow I guess.
Any way I hope I was able to help.
thanks, and i appreciate the help. like i said, i had no idea the difference was such a small amount. as soon as i get a few extra bucks to spare i'll have to pick up some new shoes for the back tires, gonna go with the 255's. i think that it wont be noticeable like you guys said.
sorry i wasnt able to get a picture other than the sig pic, not on my personal computer and i have no pictures to put up.
i have pics of my 89 rs on 16 inch iroc rims with 255's all the way around , when i get to work tommorow ill post them my laptop i use at home doesnt like the new photobucket
colton_carlson
03-08-2019 12:21 PM
eightsixseven
08-14-2015 03:09 PM
