rear hatch tint problem
Car: 1984 camaro z28
Engine: 305 5.0l
Transmission: 5 speed
Axle/Gears: stock
so the tint on my back window was bubbled really bad so i ripped it off, now the sticky residue is still there. any ideas on how to get it off?
Engine: 305 5.0l
Axle/Gears: stock
Re: rear hatch tint problem
thanks guys, never would have thought of that
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I have to remove nasty tint from the hatch window on my RS, I have never tried the acetone, but I have used a razer blad with goo gone and it worked in the past, but if you have rear defrost then you don't want to scrape on it. My RS does not have rear defrost so i'm not worried. Once I get the tint off I think I will try the acetone truck since I have some at the house.
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Acetone so a good solvent, but be real careful with it. Don't drip or spill and on the interior trim plastics, it will damage the surface of the trim.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
1 Post
Engine: LB9/3.1
I got a "new" truck a couple weeks ago that used to have one of thoase small round mirrors on the drivers side mirror but it was gone. Had some adhesive residue left behind & the Goo Gone I had wouldn't touch it, nor the residue left behind from the old registration sticker. Found my acetone later & it stripped both off with very little effort.
Car: GTA
I highly recommend NOT using heat. At most? Maybe spray some acetone on, cover it (from underneath) with some black plastic bags & let the sun heat it up. But really? Try it without any first. I think you'll be pleasantly surprised at well the acetone will work.
1 Post
Engine: LB9/3.1
Yes, be VERY careful!!! I recommend NO heat at all. I tried that once thinking I was being careful but POP! Had to buy new glass.
1 Post
Engine: LB9/3.1
I don't have a steamer and I don't have defrost, I'm sure between acetone and a razor scapper it will come off nice.
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Make sure that when you use the acetone, you have plenty of ventilation. Follow any and all cautions on the can and wipe it up immediately if you get it on the paint or plastic.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Seriously, acetone? Wow.
Warm or hot water in a spray bottle mixed with dish soap got rid of the glue after I ripped the plastic off (it already was purple and had holes in it). And it didn't stink so bad I needed to wear a respirator. Of course, I also scraped it off with a razor blade as I don't have a defroster grid (one of the reasons I hate winters with my car ).
:edit: There is also some stuff called Tint-Off, I believe...
Car: 1989 GTA / 92 Z28
Engine: 350ci
I've had 9 firebirds/camaros in the passed 15 years and never had to worry about tinting the rear hatch window. All of the cars already had tinted windows, few times i had to re tint 'em but without any issues. I recently bought one with clear hatch window, and when i went to get it tinted, there are few issues apparently. The man at the shop said that they cant tint over the heating lines that run vertically on both sides (2 lines that stick up, from which defrost lines run from) and also the thicker lines that are towards the top of the glass, they said that tints wont stick to it. I was surprised because I had one piece tint done on the rear hatch of the trans am and my z28, it was fully tinted. I never noticed if the defrost lines were there or not, I live in Fl so i dont get to use it anyway. So how do I go about tinting the rear hatch on my 89 firebird ? rip off the heating lines or...
