Macco?
1 Post
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Macco?
Alright so I was contemplating the 50$ paint job. Then realized it'd be a bitch to get off. So how much does macco charge without jamb's and some bondo. I just wan't it resprayed and fix the chips in the paint and make it all the same red. How much do they usually charge?
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Macco?
I had a bad experience with Maaco. I was flipping a Lincoln ls and did the primer and body work myself. It was done right. I had Maaco just shoot the car single stage black for $300. I went to get the car and it had a ton of orange peel, a huge sag in the door, and it looked like the 'professional' painter hit the car a few times with the air hose and tried to spot it in after the car was baked.
Needless to say, I spent far too many hours on this car making it look presentable than It was worth. I say don't do it.
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
Re: Macco?
MACCO $600
And MACCO $700
Do the body work yourself
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Macco?
maaco is a franchise , some are good some are not . ask your local shop for referances . check out the track record they have . good luck .
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Macco?
Maaco gets an unfair bad rap from A few really bad jobs out there. Talk to the manager, explain your fears, look at some examples done in that shop (they should have a few cars waiting to be picked up) and make sure that if you have sags, drips and other obvious problems, it will be corrected.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Macco?
Judging the pics I have seen, they look very good. The problem lies in what happens in the future.. If you do all the body work yourself and get everything right, I think they can lay some paint and buff it out.. With that being said, I am a firm believer that you pay for what you get.. If you spend $300 on paint and Clearcoat, you have what you have.. Is it quality paint? I am very novice and am going to find someone who is going to do my project, but with that, I am paying top dollar... It is a preference of what people can afford.
Re: Macco?
macco 5-600 $'s cant recall exactly its been about 6 years
car looks just as good as the day it was painted
Car: 1987 IROC-Z
Re: Macco?
Those look really good. They must take alot of pride as it shows... Did you have any overspray or problems that you had to fix, and what prep work did you have to do? Was the car shelled are as they sit now?
Re: Macco?
no real body work , we fixed 2 very minor rust spots on the rockers , and a lil bit of work were we welded in the wheel tubs.
other then that we scuffed the factory paint and sent it off , car only had 14k original miles on it , was owned by a nun who drove it 2 miles back and forth to the grocery store
we trust the owner of that so much we even sent the car with the weld wheels on it and not a single spot of overspray on them or the tires
we did take the trim off and pull the engine/trans before we sent the car off since we redid all the trim in house not to mention the trim is hard to come by so we didnt wanna risk somone damaging it
they even masked off in the engine bay were i had painted the bottom of the car with gm chassi black resto paint , the whole bottom of the car was black and up onto the front frame rails .we did tell them to not worry about the trunk though as we knew we were going to spray it with grey trunk splatter paint
they even masked off under the rockers so they wouldnt get the yellow under the car
when it comes to macco u really need to research each indivudal shop , alot of them dont care about quality but rather the volume of cars they can paint , these are the shops u need to stay away from
a good shop owner will sit down with u and adress any concerns u have about the paint job
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Macco?
Looks like your local Maaco is better than mine. This is when I dropped it off.
This is after 3 weeks of color sanding and polishing.
Re: Macco?
but like i said we know and trust the shop owner
1 Post
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Re: Macco?
Ok well have you considered the $100 rolled on paint job, im in the process of doing it now, and have finished the hood already and it looks like a new sprayed on paint job but it sure does take some time and effort if ur willing to put forth ill help you through it if needed
Re: Macco?
mine came out very nice u couldnt tell it was rolled on but it served its purpose as a tempoary paint job and has been stripped off the car
take the 100-150 bucks in supplies u need and put it away , then put away 10 bucks or whatever a week when u have enough take the car to macco
u will be miles ahead
1 Post
Car: 91 Z28 camaro
Re: Macco?
been there done that stop while ur ahead
1 Post
Car: 91 Z28 camaro
Re: Macco?
I will say though that ur yellow car looks great for a macco job but it might have been luck that it turned out so great, regardless nice paint
Re: Macco?
a friend of mine has an original 1970 monte carlo and prepped his car himself and had it ready for spray Macco did it (this was in 88) and it came out great (metallic astro blue). he still has the car and it is still a show car and in great shape. I had a 57 Chevy in 89 and he helped me prep it and again it was like glass. 0 orange peel! I no longer have the car but it was really nice 70 K documented miles on her.
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Macco?
That sounds scary.. Unless i was just trying to make a beater look better, nobody better go anywhere near my car with a roller.
If that works for you, that's fine. I think that statement just adds to the negative stigma associated with these cars. I'm not trying to be a downer or poo-poo your car. Just saying that it's a practice that I would not trust for a high quality finish. I'd go to maaco before i rolled anything onto my car.
Car: 1987 IROC-Z
Re: Macco?
I am now thinking that now Macco is getting a bad rap or everyone else is seriously over charging.
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Macco?
I've had 3 Maaco paint jobs. The one I had the most trouble with was the highest priced one with a clearcoat. The clearcoat peeled off in about 3 years. Stick with one of the cheaper options. But check out the work that is being done at each particular shop. They do not all put out the same quality of work. I'd personally stay away from the ones that do fleet cars. Those they "scuff and shoot" and it shows.
Re: Macco?
yeah, if I was getting a maaco job, I would get a single stage paint, pay for an extra coat or two, and then I would wet sand and buff it to a mirror finish.
Cheap clear can be problematic, with the respray window, ect...
Car: 1987 IROC-Z
Re: Macco?
The only problem I have currently is I am going to have ghost flames and the IROC-Z will be airbrushed on.. That is why I think I have to go else where.. But, I must say, that my opinion has changed from some of the work that I have seen..
1 Post
Car: 91 Z28 camaro
Re: Macco?
Its basicaly the way they use to paint cars in the 80s-90s
you get a high density foam roller, and start with 600wet then sand and work you way up to 1500 or 200 gritt like 8 coats or 6 coats total, then buff and polish its really alot better then ur thinking. ur picturing some trailer trash guy on his lawn with a bif roller and just slapping it on probably lol, its as good as a spray job but dont let me save you the money and mess
Re: Macco?
ive seen good and real bad come from maaco. i also think it depends on the individual doing the work, and the quality of paint.
never seen any cheap spraybomb, brush, or roller jobs hold up after any considerable time.
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: Macco?
I understand that it's an affordable measure for many. However, that's like comparing the new england patriots with the detroit lions.
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
Re: Macco?
my Macco experience was good, just do the prep yourself, remove everything u dont want paint on lol and send her off.
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Re: Macco?
I had my car painted at Maaco. They did all the body work, the doors were really wavy and had some dings. I took off all the gfx, spoilers and rear bumper. I stepped up and got their most expensive paint job and then had them two tone it on top of that, with a silver pinstripe to break it up. I spent $2400 on mine and it looks beautiful.
Here's the before;
Here's the car after swapping the gfx, bumper covers and spoiler.
During the bodywork
During the paint:
After:
I would absolutely take any of my cars back there, including my Iroc to get it freshened up. My Maaco does full on restorations of musclecars and I got to see several cars in process and completed. I was really impressed with the work they were doing and it made me feel completely confident to have them do all the bodywork and spray my car.
Here's the before;
During the bodywork
During the paint:
After:
#42
1 Post
Car: 91 Z28 camaro
Re: Macco?
sorry but im going to have to call B.S as i remember reading one you can add hardener in the paint but its un needed, and 2. Im not 100% sure if im remembering correct but the buffing and polishing is for the extra protection and it's supposed to be done like 2 times a year, but anyways t's not as good as a sprayed on paint job? It can be as good as you want it to be as the more wet sanding and more coats you do the better it gets. Im not sure if you read any of the hundreds of forums that have a few members doing it but this works wether some people will agree or not, and i know for a fact as m seeing great results and im not even tying that hard to make it perfect and i do a little paint every weekend. Just go look it up if ur going to say an opinion before trying it or, doing alot of research witch i have done both.
#43
1 Post
Car: 91 Z28 camaro
Re: Macco?
#44
Re: Macco?
ive did this exact paint job unlike others who bash it and have never done it
red will turn orange or pink if u dont constantly buff and wax it
blue turns to a pastel blue color
white will yellow over time
etc etc
not to mention the fact that all ur wetsanding now while u paint is for nothing , it takes atleast 2 months for the paint to fully cure , so between each coat that ur wetsanding it will shrink as the paint dries causing more orange peel down the road
not to mention u cant paint over the stuff once its on the car u need to strip it to bare metal
by the time u do the cheap paint job and get it looking half decent + the upkeep on it u could have goten a real automotive grade paint sprayed on the car
my paint stayed soft for 3.5 months after i put it on and i live were there is 0 humidity and its always atleast 80* in the summer typically its much hotter in the day
so go ahead and keep painting ur car with it even though im telling u ive been there and done that and its a waste of time, other members here who have done the same exact ppaint job will tell u the same thing
#45
Re: Macco?
oh and btw u could have went on summitracing.com and got 1gallon of real paint + the right reducer + the right activator for 80-120$'s for the whole kit and put that on ur car with a roller and be miles ahead as its real automotive paint with the correct hardners and uv protection agents
if u wanna do the roller method atleast get the right kind of paint , but do note that metalics will not roll on right
#46
Engine: 305 TBI
Re: Macco?
This seems to have evolved into a Maaco/Roller paint job thread. I've already stated my opinion about Maaco (for it) but I have also roller/rattle can painted an old '69 Nova that I had as a work car many years ago using flat black. My youngest daughter helped me paint the black. We then taped off the front end and airbrushed on some flames. I drove that car for about 3 years and never touched the paint again and still got compliments on the paint job even with rusty (but flat black) wheel wells. That being said, I think that you need to go with whatever paint you want and can afford. Make it "pretty"
#47
1 Post
Car: 91 Z28 camaro
Re: Macco?
ive done this exact paint job , ive wetsanded and buffed the hell out of it, i know how well the paint holds up or should i say doesnt hold up.
etc etc
etc etc
#48
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Macco?
Let's keep on the topic, but with a different question:
Anyone had Maaco do their body work, not just shoot the paint? My 88 needs to lose, literally, 3 coats of paint and bad filler jobs.
#49
Re: Macco?
first hand experiance , we used to use this paint to paint machine fixtures and machinery, on stuff used and stored outside the stuff would not hold up
#50
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Re: Macco?
Main reason I did my own body work was that the price they gave me kept getting higher and higher the more he walked around my car. I decided to do all my own body work over the next month, and it worked to my benefit. I gave them less chance to make a mistake, and It probably cut the price by 2/3.
