What to use to clean under car
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
was wondering what people use to make the under side shine and clean looking for a weekend project thanks such as paint degreaser what ever you use
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: What to use to clean under car
if i were you , i would start with a lift & a pressure washer . good luck .
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
no lift car is really clean just looking to take it to the next level shinning
i understand , i thought my car was clean also . i'm fortunate i have an outside lift . the first car pressure washed underneath cleaned dirt/crud from places we never knew were places . i know not everybody can do this . it's a wet & dirty job but worth it . good luck .
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I here WD40 is good,it's supposed to remove a lot of surface rust on the springs,cross members,etc,etc.I haven't tried it, but I'm considering it.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
will use try the wd-40 method i use it on are Rc cars ad really works great thanks
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
i used a mixture of SIMPLE GREEN and water on my camaro and it looks great. use a tooth brush to get to hard to reach spots...
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks for the advice just ordered some grits garage undercarriage cleaner will post some pic when done with a review
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
imo the oil all over the bottom helps prevent rust.
I put on a respirator and used liberal amounts of wax and grease remover on several rags. I scrubbed everything underneath. I also removed the tin heat shields, cleaned them up and clear coated. My exhaust is already down in preparation for a 406 SBC install. I got one of those little 3 inch rollers, a gallon of chassis saver, some old paint brushes, and went to town after some light wire brushing (very little rust). After that, I used a can of rubberized undercoating to hit all the little nooks and crannies the paint brush and roller couldn't reach. I also used a can of rubberized undercoating on the wheel wells. I used a piece of cardboard to cover the pinch of the wheel well as I sprayed. It's safe to say, my 91 RS will not be rusting "anywhere" underneath any time soon. I'll post some pictures sometime.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Also for suspension and real oily, caked on dirty spots, scrape most of the material off using a putty knife before spraying it down with degreaser. I put my car up on 6-ton jack stands in my driveway. Put on an old pair of swimming trunks, old t-shirt, scraped off the heavy material, sprayed down the under carriage, brushed it then used my pressure washer to rinse it off. The water sure kept me cool since I did this during August before the T/A Nats.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great guys going to start cleaning tonight anf then will post some pic of how well the griots undercariag works/loooks
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
db057
08-11-2015 10:11 PM
