Where to buy the Turn Lights Housing...?
1 Post
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Ok So my turn signals are real fogged up and I was wondering if someone knew where to purchase these?Im also ot looking to spend $300 on a pair thanks!
1 Post
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: Where to buy the Turn Lights Housing...?
These are NICE!
http://www.ebay.com/itm/New-Drivers-...-/230854669646
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
many do not know that early ones are different . remove your's , put in a sink with hot water & dish soap . slosh around untill inside is good & clean . rinse well , let drain & dry , repeat as needed . (make sure lwr. drain holes are good for condensation drainage) then wet sand with very fine grit & polish . has worked for me . good luck .
Thirdgenranch, 1AAuto, Hawks just off the top of my head.
Articwhitez did a " how to " using a dremel & some polish-- looked great when he was done.
Also, IDK if it would work on this type of plastic but there are a couple vids on YouTube using toothpaste & window cleaner to de-haze headlights plastics.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I just used the 3M kit to do a set of headlight lenses on a Grand Am and they turned out great! The key is not to rush through it and take your time.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
none of those companies has what he needs
Anybody posting here needs to notice the OP has an 84. those can be much harder to find than the 85-92 style. If you really know somebody that has some 82-84 style turn signals that are available, links would be helpful
this is what an 84 parking light housing looks like
http://www.ebay.com/itm/82-84-Camaro...a76b42&vxp=mtr
looks like plastic to me. Gm hasn't used glass parking light lenses in the last 60 years
http://www.ebay.com/itm/Chevrolet-NO...5136b2&vxp=mtr
1 Post
Engine: LB9|TPI
well DUH! that does change everything
makes me wonder then why he thinks he has to spend $300 then.... unless he's actually talking about FOG LIGHTS and not turn signals
