Painted TPI...Tell me what you think!
1 Post
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
Hey guys...I started my cam swap and picked up some 1.6 pro mag rockers so i got the GTA out of commision right now. since im pulling her apart I figured she deserved some TLC so I decided to take down all the TPI stuff. Im a sucker for pontiac blue. so the block will be blue. all accessories will be matched acordingly either black and blue or black. painting and lining the fuel rails tomorrow ill have more pics then but this is what I have thus far. let me know what you think.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Painted TPI...Tell me what you think!
Cant tell how much I like them with pictures so small. If the blue matches the car or bay I would assume it'd look pretty nice. If not then I would imagine it'd look kinda silly.
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
The blue is a bit stark, but I like the black.
And when you said painted TPI I imagined I was going to see a painted tuned port injector. Not painted valve covers...
Car: '89 GTA
Cool idea but it's looking too... "stripey"!
with this kind of theme (Pontiac motor) I'd try to keep it more true to how they originally looked back then instead of trying to make it look a bit fancy. So... I would paint the valve covers all blue and then do the whole intake in something like a low glass black... JMO.
Car: '89 GTA
1 Post
The car is black.. the intake and runners are gunna be black as well. they came out a little lighter than i thought they would be I still like em. Im gunna clear over them tomorrow and finish the fuel rails. wanted to pick up some braided hoses also. thats about it as far as what i want under the hood. I feel the pics dont do them justice. they seem a bit darker in person.
i like how u did it i just dont like that color blue
here is what i did on my twin turbo iroc
im prolly going to strip the runners and polish them, and then polish the lines on the tpi plenum and leave the blue
i used krylon metal coat paint it has a metalic silver base coat and then they make the top tranclucent coats to go over it in all different colors. in the sun it has alot of nice sparkles in it.
the runners are done in only the base metalic coat and they also have that nice metalic sparkle
heres a 76mm turbo i did with it too u can sorta se ehow glossy this stuff comes out
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I like the stripes. But what is important is if you like them.
1 Post
@Project89: I almost used the same thing. had them both in my hands just decided it would probably be better if they matched the block. but those are definitely sharp.
@richboll: I do. they look great imo.
cant wait to put them on....might be a month or so before its all together :/ (accumulating piece by piece) just cause im trying to get my hands on a sdpc vortec intake and slp runner... picking up the vortec heads this upcoming weekend hopefully for my 1.6 rockers and valve springs
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
SR71BLKBRD, That looks sharp. You did an excellent job taping things off so they look great. I like it.
Project89, I have that same Krylon paint on a shelf in my workshop/garage. I wonder if it will hold up to the heat of turbos though. It looks great 4 yrs later on the Holley carb on my Olds 350 powered boat.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I think it would look better if it was actually Pontiac blue.
1 Post
Car: 1987 Pontiac TransAm GTA
Engine: Vortech S-Trim, 355cid
Axle/Gears: Mosier 12bolt, 3:73 Eaton locker
Here's kind of a common theme I've seen before, but hey, ya do what you can....
Last edited by blown87gta; 07-30-2012 at 09:24 PM. Reason: img link didn't show up
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
I'm not a fan of the colors but the.work came out great I'm sure it's goin to look better all bolted up to that motor.
Engine: 305 TBI
I think it looks good. What color is the car? The fender looks about the same color.
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
