View Poll Results: June COTM
jbenge
2.89%
theswede
18
10.40%
BIG_MODS
41
23.70%
Kevins89Formula
52
30.06%
Norcalz28
25
14.45%
fasteddi
6.36%
1FastZ
3.47%
black88cam
8.67%
Voters: 173. You may not vote on this poll
June COTM *VOTING*
COTM Editor
June COTM *VOTING*
Here are the top 8 cars that received at least 2 nominations
jbenge
theswede
BIG_MODS
Kevin89formula
Norcalz28
fasteddi
1FastZ
black88cam
jbenge
theswede
BIG_MODS
Kevin89formula
Norcalz28
fasteddi
1FastZ
black88cam
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Re: June COTM *VOTING*
LS swap nearly complete, I'll post up an new pic or 2.
Car was 2830 lbs dry with the Iron GenI motor, expecting to drop another ~75 with the LS and QM clutch.
Website: www.f-bodysport.com
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Some better pictures. Alot of hard work on this 3.1L V6
Heres a little more info about my car. I've had it since 93, started out as a daily driver stock LG4 when I was a senior in high school. I built up the LG4 and got to down to a 13.4 1/4 mile. Then I built a 383 that started as a mid 12 sec combo that evolved into a high 10 sec combo. Then I build the 408 LS engine that is in the car currently. Its ran mid 10's with trans issues and a lean condition and should run low 10's once I get all the bugs worked out. I've only made about 10 passes on this combo, none this year yet. Just got the new trans and converter in, new fuel pump, and now I need to get my carb sorted out. It runs on pump gas and is driven to the track, I don't even own a trailer.
408CID LS
Super Victor Intake
TFS 220 heads, hand ported
Callies Compstar forged rotating assembly
1000cfm 4150 carb
TH-400 w/ reverse full manual valve body
Ultimate Converter Concepts 8in converter
Moser 12 bolt w/ spool
richmond 4.30 gears
chrome moly 6pt roll bar
subframe connectors
1in rear sway bar
LCA relocation brackets
tubular LCA's and panhard bar
Spohn K-Member and A Arms
Spohn coil overs
Kirky seats
custom dash panel with Autometer Gauges
408CID LS
Super Victor Intake
1000cfm 4150 carb
richmond 4.30 gears
subframe connectors
1in rear sway bar
Spohn coil overs
Kirky seats
and a few more pics.
short idle video
http://www.streetfire.net/video/408-...le_2254356.htm
my build thread
https://www.thirdgen.org/forums/ltx-...p-into-my.html
short idle video
my build thread
Car: 1991 Camaro RS
v 3.1L V6 60 degree Engine
v 8.5:1 Compression Ratio
v 260 Adv. Delta Camshaft
v 1.5:1 Rocker Arms
v Walbro 255LPH High Volume Fuel Pump
v LC2 28 LBS Fuel Injectors
v AC-Delco R42TS Spark Plugs
v Taylor 8mm Spark Plug Wires
v Fully Ported/Polished Heads
v 3-Bar AC-Delco #16040749
v Waste Gate Actuator AC-Delco #214-474
v Stock 1227730 ECM with $59 Sy/Ty Mask
v Moates Burn2 Chip Burner/27SF512 Chips
v Tunerpro Rt Tuning Capibilites Via Laptop
v SLC DIY-2 WideBand Oxygen Sensor Kit
v 57-1mm T3/4 Hybrid TO4E Turbocharger
v JDM 38mm VR Style Wastegate
v JDM Type-RS Blow Off Valve
v JDM 28”x7”x2.5” Intercooler
v Custom Exhaust Piping
v Custom Charge Piping
v Magnaflow Muffler
v Fully Exhuast Wraped Piping
v 3.23 Ratio 7.625” Series 3 Carrier Rear End
v 700R4 (4L60) Automatic Transmision
v 2800 Stall Converter
v AFPR set to 55psi @ Idle
A little Info on my engine set up.
v 1.5:1 Rocker Arms
v Magnaflow Muffler
I voted for big_mods just cuz his car is one of my long time favorites... but jeez you guys have some nasty nasty rides!
Kevin89formula must be the prettiest Formula i've ever seen. Norcalz28, your car has an absolutely wicked very nice sleeper look to it. Very tastefully done car! Jbenge, that thing is just awesome! And fasteddi with your "just a v6 camaro..." look... LOL, very cool car.
It's almost unfair that only one person can win sometimes.
norcalz28... is that a 350 or a 383? How much power does it put out with the TPI on it? Those runners look huge, I thought it wasa FIRST TPI at first, but the plenum doesnt look like a FIRST.
Thanks. They are Accel runners that have been ported by Lingenfelter. The stock base was ported to match, as was the plenum. It started out as a crate ZZZ, 350 with 113 heads and carb intake, forged crank, pink rods and hypereutectic pistons. I swapped over my AFR heads, comp cam, and TPI.
I have not dyno'd it yet. But based on quarter mile times, I'm guessing it's only making about 250-260 to the wheels right now. Needs a tune to get the most out of the combo. Keep in mind it passes CA smog as is, nowhere close to the max. It's cleaner than my '01 S10.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Beautiful cars.
Very few photos can be placed side by side with out stretching the page.
Stacking just makes it nicer.
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
1 owner car, got her new when I turned 16 in 1989.
To many mods to list them all. Here are the highlights
Forged ls2 402 ci, TVS 1900 magnuson supercharger with rear cog drive,
610 rwhp, 643 rwtq
built T-56, spec twin disc clutch
Every suspension part you can have (ha ha), won't list them all
Narrowed moser 9" rear
18" boze wheels, 14" rotors, 6 piston bear brakes front and rear.
corbeau seats, interior work, and of course got to have some boom boom.
big thanks to Hawks (Bruce is The 3rd gen man) and to my local "ls" shop G-force.
latest dyno pull
http://youtu.be/mjfQc2aSrvc
[IMG]
610 rwhp, 643 rwtq
latest dyno pull
[IMG]
kevin89Formula.... that car does NOT look like it has that much power. Looks like a beatifully preserved 5k mile garage queen with some sweet, sweet wheels. Amazing to have that kind of power hidden under the hood without a bunch of dead giveaways all over the car. It's kind of scary to say it, but at that power level, even that car is a hell of a sleeper.
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Damn, it's not fair that we can only pick one car for this month! Well, if my other choice does not win this month, I know who I will nominate in the coming month!
Car: 1991 Camaro RS
I have got to say, I knew my car didn't have much of a chance on COTM. But there is some very nice thirdgens on here. Props all these cars.
Car: 89 formula 350
Transmission: t56
http://s746.photobucket.com/albums/x...t=kevincar.mp4
alot of really cool cars in this thread.
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Lots of nice cars this month, going to be a real tough decision.
kevin89formula,
I really like the wheels and stance. The wheels are unique and really set off the subtle style of the car. Thats how I like a car to be done, clean and subtle. The car appears close to stock on the outside except for the wheels but once you look closer there are way more mods....perfect, very well done. This is the first time I've seen pics of it.
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Big mod I never seen your car around what city u stay by. I seen your build post if I seen your car on the streets I would took a million pics.
Kevin your T/A is alsome in every way I don't like to many birds but this has to be 1 of the best.
Good luck to all. 1 day I hope I can on cotm
Car: 1990 RS
Transmission: Built-700R4
Just voted, some incredible cars on this thread.
Kevin, firebird is F' hot!!!
BigMods I think you need to reinforce the chassis some more.....That is awesome, I've never seen a cage like that!
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Car: '91 TA vert
Engine: turboLSx
Some really nice cars here but after having spent a loto of time around the Epic IROC of BIG_MODS I can vouch that his car is on another planet. Driven to work on nice days, track driven and did Power Tour last year in a monsoon of a storm... I would bet some of the other cars never get rained on...lol
Car: 1991 Z28
Engine: 5.7 TPI
My vote kevin89formula. I drive a Camaro, but that is a beautiful Firebird... and that motor is downright SCARY! I let my son drive the Z28 quite a bit, but I would not let him NEAR that thing!! It would be wrapped around a tree in no time. What are the seats? Nice door panels, by the way...
Car: 89 formula 350
Transmission: t56
alot of nasty lsx cars out here.
corbeau seats, had them recovered in leather.
I like BigMods car,pretty sure he wants the car he built (track car for street) and I want the car I built (semi car show/street). both cool cars, just serves differant purpose. whatever the outcome in the voting it is a really fun thread for me to be in.
700 hp + drag radials + rain = sux
I am going to the Holley LS fest this September in Bowling Green KY.
bring out your car popeofpaint and we can line em up... unless its raining of course.
I'm tempted to vote Formula just for the lip on those rear wheels. 18" by what? And what offset?
But BigMods has an amazing car that is probably a blast to drive, a v6 running L98 times, ghost flames on a drag car.... Man, tough choices....
#42
Car: 87 IROC
Engine: 5.3L
Sojer, I'm in Royal Oak. I was on Woodward Saturday. I just got the LS engine running we were tuning it. I ended up bending the TA so I'm building a new one now
#43
i had to vote for the v6,specially since i nominated him, but if it wasnt for that big_mods would have my vote that is one sick car man, i love unique builds and that is deffiantly one
but still cant get any more different then a high hp v6 build
#44
610 rwhp, 643 rwtq
latest dyno pull
[IMG]
610 rwhp, 643 rwtq
latest dyno pull
[IMG]
Specially like the interior
#45
Engine: gone
Transmission: gone
Axle/Gears: gone
BADNBLK the amount of voters for COTM has went up every month right? overall votes I mean. I like what you set up and glad JT is working with you on it. Good stuff.
#46
COTM Editor
I'm really glad that the system is working and everybody is playing nice with it! It has been really fun to see what cars get brought out of the woodwork, and other members reaction to them!
#49
Car: 1991 Camaro RS
I just still think its amazing the fun a Turboed V6 is and how unique it is. Everyone look at project89's sig pic and your see what motivated me to do my build. Im sure you'll see the resemblence between the cars without even looking at the motor.
#50
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Makes me wonder how next months nominations will turn out ....they keep gettin' better and better!
