1989 GTA Pinewood Derby car
Finally beginning build on our PWD car cloning my GTA. (yes, I do have a Formula hood on mine) Tricky to stay within the scout specified wheelbase. Starting version2 tonight with longer, correct, frontend. The will be coated with PPG metallic flame red. foglights and taillights will be functional. This is a blast.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 1989 GTA Pinewood Derby car
Looks way better than the CNC 6061 one "I" built years ago for the Unlimited Class in my local Autocriss club for the year end party. Only rules were non-powered (gravity only) and a 1lb weight limit.
My boss programmed the CNC mill that I ran at work, so I didn't exactly have control over how un-close the profile came out. I just did the set-up & ran the mill.
Thanks, that 6061 could've been so cool with the correct lines...Working on V2 tonight...
Car: GTA
My wheels & tires were CNCd on a Lathe out of 6061 & the black "tires" were Delrin. Afterward, I realizede I should have been so "accurate" in making them wide for looks, but narrow for less rolling resistance. I wanted to CNC the "tires" into smaller diameters except for 1 thin section, so that they still looked wide, but only the thin part was in actual contact with the track for a smaller footprint.
Did you CNC that? Any way you can reduce the tire footprint on those?
Nope, all Dremel and hand sanding...about 5hrs..Cant touch the wheels per our packs rules, but I am moving the body forward about 1/2" on the next one to achieve the right front look on V2. Have to run the predetermined wheelbase. Putting LEDs in the driving and taillights. Thought about getting a recordable soundchip out of a greeting card and doing motor sounds too. Gotta stay under 5oz total though.
Car: GTA
Impressive work. Your hand carving turned out way better than my CNC work. I wasn't exactly happy with it, but the programming was free as well as the machine time, so I wasn't gonna get picky. I just had to pay for the block of aluminum.
Whatever weight you add with a battery & LEDs, can you carve the bottom out to the weight back down? That is why my bottom is carved out. Multiple CNC passes to get the weight down.
Car: 85 Z28
Engine: 327
Lots of things you can do with wheels. On trick is to hone the hubs. Second is to raise one wheel up. One year I, I mean my kids of course, made a 63 split window vette and a Ford Daytona coupe. Vette win four trophys, and coupe 1. Also Polish the burs of the nails.
Thanks jchaussee, In our pack, all four wheels have to have contact and they are very strict on messing too much with the wheels. Planning to hone the hubs, and polish the axles...we are also permitted to only use graphite as a lubricant. One thing I will make certain of is the straightness of the axles. Bought a few kits that had slightly bent axles...
BTW--I will be going thru Bellingham next month. My company has a HQ there and Burnaby.
thanks guys, V2 will be ready soon with a more correct wheelbase...
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
wow that is awesome I remember back in the day when I used to build these for boy scouts. One time this kid showed up with a awesome second gen ta inspired pwd and it blew my mine
Is there anyway of paying you to cut me a 3rd gen t/a? I drive a semi and dont have alot of time at home. My 6 year old son is in the scouts and wants a trans am like my 86 t/a.i havent the time or ability to do it right. i can do the wheels and paint and the finish sanding just cant do the shape...
When would you need it? Not worried about the money, just time....I assume you're in Missouri?
No hurry really they just had one and he did the batmobile. But they are planning a "fun" race between local packs in March or April which would be cool but its totally up to you...I showed him the pics of yours and he didnt believe me that they are of a real pinewood derby car lol
Lemme see what I can do 86TAINMO...
Here the posts with the cars in racetrim...running tomorrow
https://www.thirdgen.org/forums/auto...ml#post5163589
