Slammed Third Gens - Post Pics
#151
Re: Slammed Third Gens - Post Pics
I've never been a fan of prostreet cars, but yours is the exception because it isn't tubbed and retarded. Your car just looks good.
(but lol @ the mudflaps with the blower)
#159
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I've said it before, and I'll say it again--this car is simply stunning the way it is set up with those stock wheels. These wheels are always overshadowed by the IROCs, so I think sometimes people forget just how good they look, even if they are just 7" wide.
lots of very nice rides in this thread, makes it easy to see why I still love the third gen look
#160
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
lol, I keep coming into this thread just to stare at your car, that is just the epitome of a perfect stance.
#162
Engine: 5.7 350 TPI
any new ones??? im going lower soon once i roll/cut my fenders
#163
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
My 86 will be on the floor again tomorrow hopefully with the Intrax's. I will snap some pictures/videos if I have time.
#164
Engine: 5.7 350 TPI
dope those intrax are supposed to sit mad low too..interested to see the outcome for sure
#165
Yep, I was running Moogs/AGX all around and this was the result.
I have only done the passenger front and the drop after a week looks good. I will have the car on 3/4 Intrax on monday hopefully for some pictures.
#167
Guess I didn't make it clear, those pictures are the befores with the Moogs. I will try to get some better pictures with 3/4 intrax tomorrow.
#168
Car: '88 Trans Am GTA
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
#177
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Front:
19x8 Auto Art 3 piece VY design front
1 3/4" lip
4" backspacing
fender height is 26 1/4"
275/35ZR19 Bridgestone Pontenza RE050
Rear:
19x10 Auto Art 3 piece VY design rear
3" lip
5.5" backspacing
fender height is 27"
295/35ZR19 Bridgestone Pontenza RE050
1 3/4" lip
4" backspacing
Rear:
3" lip
5.5" backspacing
#178
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Indeed it can be, and will be. Unfortunately my ground control set up it bottomed out, so I'm going to need to get shorter springs. This car is also going to see competitive autocross this year so there's a whole lot of parts that I still need to save up for.
#180
Engine: 5.7 350 TPI
i still need LCA's, LCARBS and the whole torque arm setup as well as new steering linkage to finish it off for now
whats your suspension setup btw? if you dont mind me asking of course
#181
Engine: LB9, LB9
Ground control weight jacks with SSS 800lb front, 200 lb rear springs. KYB adjustable struts and shocks, bull dog double adjustable rod ended pan hard bar. 36/24 sway bars with poly endlinks. I'm trying to get it set up before march, and I still need: 900/250 springs (and shorter), LCARBS, Koni yellows, extended ball joints, solid strut mounts, subframe connectors, strut tower brace, relocate both sides of the panhard brace, offset a-arm bushings, jeep steering shaft, bump steer kit. And I'll just use that as a starting point.
#182
Engine: 5.7 350 TPI
sooooo dope!
#183
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
#184
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Mine before my build....might not be considered "slammed" per se, but it's one of the lowest in my area. Tokico 1 3/4" drop springs and Tokico blue shocks on 18" Ruff 278 wheels. I have a very good feeling it will sit even lower now from the added weight of the turbo parts/intercooler on the front end.
#185
Car: 91 Camaro RS
Engine: TBI
Yall got me snooping around on here and looking at old pics again
Cars and bikes= On the ground
Trucks= Up in the air
Perfect example of slammed vs. lowered
Slammed vs. not slammed
Slammed bike
That car started it all for me with the lowered stuff, now everything i own aside from the trucks just dont look right if they're not in the weeds
Slammed bike
#186
to the people posting pics of "slammed" cars. if you can see a gap between the tires and fenders, your cars not slammed. if you buy a lowering kit, your car is lowered. slammed cars are usually people who install air bags to get that slammed ride height. my car is lowered 2" all around and its not slammed, but after the adjustable suspension is done it should be. i car usually isnt drivable when slammed, and if it is it will be a nightmare to drive. this is only my opinion. please dont get offended.
#188
someone had to say it......lol
heres another way you can tell. if your driving your car and it feels like your butt is going to scrape the ground while driving. your car is most likely slammed....hahaha (personal experiance from previous camaro)
#189
Car: 1986 Trans am
Engine: 5.3 LM7
Slammed is a pretty generic term if you ask me. Obviously some of the cars that have a few inches between the tire and fender are not "slammed" but for a road driven car, I'd consider around an inch gap to be pretty damn low for a street driver! Plus, airbags and all that just are not very practical for the majority of people, and I for one think it's kind of a waste to go through all that trouble and custom work just for a "look" that will not do much for actual handling improvements. With that said, I always considered slammed to be pretty low, but still driveable for the most part...as in not tucking half your wheel into the fender.
#190
#191
Car: 91 Camaro RS
Engine: TBI
Back in the day they werent, my setup out handled the dozens of different combos of springs and what not i had ran on that car over the years before the bags. I wouldn't hesitate to spend that money again!
#197
i only rolled my fenders because of the rims i have now. im getting out of my 17's because there not what i want anymore and i dont want to use the 2" adapters needed to use them. i want to run 8" wide fronts and 11" wide rears. maybe a 15" rim.
#199
Engine: LB9, LB9
I tweaked a few things and managed to get my car lower. I'm now tucking tire front and rear ever so slightly.
Please excuse the dirtiness. I haven't washed her in almost 2 weeks.
