Slammed Third Gens - Post Pics
#452
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Slammed Third Gens - Post Pics
I've removed mine entirely. In fact the rear sits about 3/4" from where the bump stop used to mount. I'm going to section the bump stop mount and lower my shock mount to gain clearance and travel.
#454
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
Just for some perspective what do these late third gens sit at so Iroc's T/A's and GTA's stock?
I really like a couple of these cars height's trying to figure out what I am going to drop mine....
#455
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
STOCK Vs Lowered
Stock fender Height should be over or around 27" Front and 27.5" rear estimation on new suspenion depending on how old your shock springs if there work could be lower than that
My ride height is 25" front and 25.5 rear
#457
Engine: LB9, LB9
Stock, measured 28" fender height
Slammed-ish, 24.25" fender height
#459
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
My third gen. I really need some better picture taking skills.
I have 2 inch dropzone drop springs and I feel like it could still be dropped more just donno how to safely. Besides iv already put holes in my 8qt deep race oil pan.
#460
Car: 1987 Camaro
Engine: 2.8 V6
Love the stance on this one. Hoping to get my next Camaro about that low. I feel kind of dumb for asking but what are ISOs? Haha
#461
Engine: 305 to 350
Axle/Gears: 10 Bolt
Rubber isolators that go on top of spring front and rear rear is thicker front it really doesn't matter if you take them out there already thin won't make a difference in lowering removing rear ISo and replacing with heater hose you can lower anywhere from 1/4in to 1/2in lower in the rear maybe more every camaro dif you cam get arid of some of the natural rake thirdgens have
#462
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
#463
Engine: LB9, LB9
No bags here, all static. I have Ground Control weight jacks with 800lb/200lb springs, Koni SA dampers, Founders raised strut mounts, Summit 1" extended ball joints, DA panhard bar, founders LCARB's, and no bump stops. Oh and I did test fit some ZR1's awhile back but I decided not to get them. 17's won't fit with the drop spindles that I'm going to get.
#467
Car: 1984 Z28
Engine: 87 carbed 305
Transmission: BW t-5
Axle/Gears: stock 3.73 posi
[IMG]file:///C:/Users/CHEVROLET/Pictures/IMG_20130123_163410.jpg[/IMG]
#468
COTM Editor
I like this thread... js
#470
Car: Camaro SC 1988
Engine: 2.8L V6
Transmission: Automatic
Some very very nice slammed thirdgens here!!!
Bit off topic but what's this sun shade called on pwdbychevys rear window? Where can I buy?
#471
Rear window visor/ rear window deflector or roof spoiler. They look really good on S14 240SX's and the certain thirdgen Camaros can really pull it off.
http://www.andysautosport.com/chevro...eflectors/gts/
It's just a stock photo but I'm preeeeetty sure that's the one.
#475
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
on gc weight jacks, 825 lb fronts and 125 lb rears, koni yellows
biggest issue is my exhaust is way too low- going to get it redone eventually...
~Steven
#476
Weight jacks, full down, sitting on the bump stops up front. Stock WS6 rear springs, didn't have the rear weight jacks in yet.
These were at 26.5ish" and 27". GCWJ, 850 front 175 rear, 8"/9" respectively. Getting an alignment (J&M strut mounts were put on too, want to see if it settles at all or changes amount of strut travel when everything's back in spec) and maybe going down half an inch to an inch more if I'll have enough travel to the bump stops. Running GC strut mounted jounce bumpers up front and stockers in the back.
#477
1 Post
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
I love the color combo of your car (Midnightfirews6). Probably my favorite non-stock looking 84 bird.
#478
Car: Camaro SC 1988
Engine: 2.8L V6
I agree! I genuinly don't like red. But the combo on that one sure looks awesome!
Btw, aftermarket or factory louvers? If not factory, could you pass me a part number? Thanks in advance!
#479
What tire sizes are you running? I can get some C5 wheels relatively affordably, but it annoys me the weird tire sizing issues they have. To get a tire that's stock height you have to go with a 245 in the front... or you can go wider and have a front tire that's taller than the rear but not as wide.... just gets weird. Anyway I ask because yours looks great.
#480
Thanks man! They're non factory Cragar 3 pieces. They're definitely 20 footers haha, need to find another set or fix a small crack on one of the edges, get new hardware and re-paint them. Craigslist or the classifieds on here are your best bet to find them, they usually go around $300. If you get a set be careful, the middle pieces are aluminum but the sides are plastic and might be somewhat brittle Also make sure you get or make hardware for them!
#481
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Got my front suspension installed last night. Took a couple pics of it with the weight jacks all the way down. Haven't installed the rears yet, need to buy more parts.
850 GC weight jacks
Koni Yellows
Hotpart/J&M products caster/camber plates
New del-a-lum bushings and Moog ball joints
itsmikey, dbltake, and any others that low, what are you doing for clearance for suspension travel? Removed liners? Any adverse effects of removing them, like dirt, moisture, and road grime in places you don't want it? Not sure if i'm going to go slammed, it may be too low for best handling geometry.
#482
Engine: LB9, LB9
Suspension travel on these cars is a bit of an issue when going that low. Ideally, you really need drop spindles to be able to get enough travel. I removed my fender liners and dirt and debris certainly does get back towards the door hinges so make sure to keep those lubed regularly. I plan on cutting the liners up and only retaining the rearward portion to prevent that. the next issue is that if you haven't removed them yet, you'll be riding on the bump stops. Once those are out then, you have another issue of not having very much travel before the A-arms actually contact the crossmember. Of course, really stiff spring rates can kind of band aid that problem. But drop spindles will move the A-arm down enough to not have any clearance issues. As far as handling compromises go, to me it doesn't feel that its as much of an issue as many people make it out to be. Since you're running a decent spring rate you won't have as much compression as someone that's running say a 650 or 700lb spring so you won't get nearly as much positive camber gain. I've autocrosses my car at several different heights and alignment specs and if you're running a lot of static negative camber and as much positive caster that you can get, then you're really not going to notice the positive camber gain.
#483
Car: 1985 Camaro
More info on these wheels and tires! Love the fitment
I just sold my e30 bmw and need moar low in my life
Have had my heart set on XXR 962's for a while but can't decide between 18" or 19" and idk what widths for front and rear. Any suggestions guys?
Thanks a lot, can't wait to post pics when I'm done
#484
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
^^^ I second more pics and info please!
fenwick , I say go with a 18/19 setup! As far as rubber sometihng like a 255 front and 275ish rear. But the wider the better! IMO (to a certain point)
#485
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
#487
A little late but it's called a SolarWing II from GTS. The slammed pic was before coilover conversion and my sig shows after coilover conversion.
#488
Car: 1985 Z28
~Steven
#489
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I wouldn't call it slammed but pretty low. Sittin' on Prokits.
#491
COTM Editor
You washing your coil over?
#497
#498
Engine: 305 to 350
Axle/Gears: 10 Bolt
Idk what you implying with your post
I know that's a coilover setup for thirdgen your and the pic above that
4th and 3rd gen spindle is different ... As is front shock setup
http://www.ls1howto.com/?article=6
http://www.ebay.com/itm/Camaro-Firebird-KYB-Adjustable-Shocks-Struts-Used-Front-Rear-/380667272700?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2000%7CModel%3ACamaro&hash=item58a1899dfc&vxp=mtr
But very nice setups
I've been contemplating using coil over for the front
The only thing I don't like is you loose some clearance for wide wheels
Yours looks like qa1 setup correct ?
#499
My rear coil overs are qa1 setups but the fronts are from PARacing
