Best grit Sandpaper to wetsand Clear coat?
1 Post
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: Best grit Sandpaper to wetsand Clear coat?
I'd say 2k. And All I would say is be careful. Its easier to sand through clear coat than some people seem to think
Car: 1989TA WS6
Engine: 305tbi being modified
Transmission: 4l60e
Axle/Gears: .73
Car: 1989TA WS6
Transmission: 4l60e
Axle/Gears: .73
3M makes an oxidation remover called microfinish,if you are using buffer be real careful.And the car has to be spotless clean,including old wax.panhead
Car: 1989TA WS6
Transmission: 4l60e
Axle/Gears: .73
Try 3M microfinish*/.It's an oxidation remover first,maybe.DONT use an electric buffer,and the car has to spotless,including old wax.Sanding clearcoat is tricky under the best of circumstances.panhead
