cleaning the coolant and washer tank
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
Any ideas for cleaning the tanks and making them white again? I did a search and everyone said to replace them, but those posts are really old and they are not available anymore.
Car: '92 Z28
Engine: 350 TPI L98
Axle/Gears: 10 Bolt / 3.23
Re: cleaning the coolant and washer tank
I have heard using Lestoil. It's a kitchen purpose item that you add into these tanks and seal them off with some water inside. Shake, wait overnight and dump the gunk away.
Home Depot has CLR,,, cleans away Calcium, Lime and Rust.
A few bucks of experimentation would not hurt.
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
There was this whole thread where someone had used liquid plumber to clean theres and it came out pretty much white...looked brand new!
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have done the liquid plumber thing . worked great , coolant tank looked almost new . clean with soap water , seal openings with sandwich bags & rubber bands . open neck , pour in about 2 cups of liquid plumber , poke a wet wash cloth in it , re-seal . slosh it around , coat the inside well . let set on different sides for about 15-20 mins. . flush tank & repeat if needed . worked for me , good luck .
ps : forgot to mention , use liquid plumber GEL .
Car: 85 Z28
Engine: 327
Also use a bottle brush to get into the nooks and crannies. But you can but them new. They are pretty reasonable
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
http://www.gmpartsdirect.com/index.c...TOKEN=43475709
14070997 (Coolant)
10078368 (Washer)
EDIT: If you're not into new, by all means try Uncle Tom's fix. After all he's been around for a long, long, long, very long time (rumor has it that he helped the Roman's wrench on their chariots) and has a ton of tricks up his sleeve.
JamesC
Not only does ModernDay sell them, but the part numbers are still good here:
14070997 (Coolant)
10078368 (Washer)
JamesC
14070997 (Coolant)
10078368 (Washer)
JamesC
How about this for the coolant tank? I didn't realize there was a difference (learn something new every day).
http://www.hawksthirdgenparts.com/ca...irtanknew.aspx
JamesC
JamesC
14070997 (Coolant)
10078368 (Washer)
JamesC[/quote]
O.K. James , i will get even . no truth to the ROMAN thing . but , i was friends with Lindberg's crew chief . ( Maj. "Stan the Man" Lindberg that is ) . i will getcha James .
10078368 (Washer)
JamesC[/quote]
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Great to hear about the Plummer Gel. Everyone always gets to the checkout page when buying these and says, "Wait, what else do I REALLY need for my car?" and off they go. LOL at least thats how it is for me...
Engine: gone
Transmission: gone
Axle/Gears: gone
14070997 (Coolant)
10078368 (Washer)
JamesC
10078368 (Washer)
JamesC
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Try these
Google - Universal Spinners. The wiper fluid has the Moroso screw top welded on.
Or just buy new ones. Always looks better under the hood.
Engine: Tpi 5.7
Axle/Gears: 3:23
I ordered the washer and coolant bottles but as I read down Its the wrong washer tank I need the one thats discontinued, oh well whats the difference at least it will be new and will look good.
JamesC
JamesC
the small tank (if you look very close) has a small tab towards center . that tab is used to support the duct work for a factory dual snorkel air cleaner . i happen to have one from an 82 parts car i used to have . did you know that James ??? (i'm still going to get you)
JamesC
1992 Trans Am
05-10-2023 07:19 PM
