MY DIY rim/wheel paint
Car: 1987 camaro Z28
Engine: 305 4bll
So when i bought my Camaro it came with a stock set of 15'' z28 wheels, they were pretty beat up and had some grim on them but after cleaning them up they looked decent, but they weren't what i was wanting, without the funds to buy some zo6 wheels or some te37's i decided to just paint the rims i had until i could afford some new ones. ![wants attention](https://www.thirdgen.org/forums/images/smilies/attention.gif)
I first wiped them down and hit them with some goo gone and cleaned them up. They were looking like this:
![Name: IMG_20101205_212317.jpg
Size: 53.0 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402011d1501442998-my-diy-rim-wheel-img_20101205_212317.jpg)
After that i used a coat of flat black 99 cent paint from wally world
let dry 5 min heat gun at 500ish degrees and let dry 5 more min:
![Name: IMG_20101210_122525.jpg
Size: 135.9 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402012d1501442998-my-diy-rim-wheel-img_20101210_122525.jpg)
Second coat, 5min + heat gun + 5min:
![Name: IMG_20101210_122538.jpg
Size: 150.7 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402013d1501442998-my-diy-rim-wheel-img_20101210_122538.jpg)
third coat, 5min +heat gun + 30min:
![Name: IMG_20101210_122547.jpg
Size: 137.4 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402014d1501442998-my-diy-rim-wheel-img_20101210_122547.jpg)
gloss all purpose clear coat, 10min + heat gun + 5 hours:
![Name: IMG_20101210_130055.jpg
Size: 95.8 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402015d1501442998-my-diy-rim-wheel-img_20101210_130055.jpg)
waited until fully dry and removed tape:
![Name: IMG_20101210_134024.jpg
Size: 89.4 KB](https://www.thirdgen.org/forums/attachments/auto-detailing-appearance/402016d1501442998-my-diy-rim-wheel-img_20101210_134024.jpg)
I took a butane torch to it and held it there for about a min and tried to scrape off the paint, not even a scratch a lot more durable than i had imagined. Looks better than the stock rims in my opinion and a lot cheaper than having a shop powder coat them/ but i am not saying if i had the money i wouldn't have them powder coated
1 Post
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: MY DIY rim/wheel paint
Very well done! Now just get rid of all the corrosion on the inside where the rim contacts the tire so you don't get a rim leak.
Engine: 305 4bll
thanks man, yeah im going to take a wire brush to it and put them on after i get my lowering springs
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Don't these wheels have a clear coat sprayed on them? I don't know how well paint sprayed onto clear will hold up. I bought a set of similar wheels and had to use "Aircraft Stripper" on them to remove the clear. Did the "Goo-Gone" look like it was removing the clear coat?
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
