Trans Am OEM Foglights with H3 LED bulbs anyone?
Looking to possibly swap the normal H3 bulbs in the original Trans Am foglights to H3 LED bulbs similar to the picture (loads of different number of LEDs on there (or actually SMDs) ... bright white.
Not sure what they will look like and if they will be bright enough compared to the OEM bulbs ... and of course the lens in the fog lights aren't designed for LEDs etc.
Anyway, anyone tried this and got some photos or views (good or bad) to share?
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Trans Am OEM Foglights with H3 LED bulbs anyone?
This sounds interesting, particularly in countrys were lights need to be on during the day too.
I will try them out, I have removed the metal "covers" on mine, for more light.
1 Post
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
You should consider the PIAA line, not sure if they have your application, but their lights produce a white light and use the same or lower current than the OEM application calls for...
The other thing you have to watch out for is that the light being farther out from the base will change the focal point of the reflector (or something like that) and cause more light scatter, this making them worse fog lights and potentially blinding other drivers.
I'll see if I can do one of mine then compare the two (stock and LED) to see how bad it really is ...
Car: 87 GTA
http://www.austinthirdgen.org/index.php?pid=25
The shields are pretty easy to remove & cause no problems with oncoming traffic or light output problems.
Also, most of the after-market replacements don't even have the shield.
ambainb
04-25-2016 09:21 PM
Doogie92Z28
03-17-2002 10:40 PM
