My black car gets dirty so fast!
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hello guys,
My car looks really nice after I wash it, and it stays shiny for about another 4-5 days...then it starts looking all dirty with dust all over it and everything, especially if it rains. I wax the car twice a year (using turtle wax), and wash it at least every 2 weeks (more if it rains a lot). I've never had this problem with other cars I've had in the past.
If it rains, it will leave little white spots all over the car (apparently it happens to cars that are waxed).
Is there anything I can do to my black car to make it look cleaner for longer? I really hate washing the car every week...A friend of mine recommended getting the car professionally detailed. Will that help?
ANYONE KNOW HOW YOU CAN KEEP A BLACK CAR LOOKING CLEAN FOR MORE THAN 1 DAY? (OTHER THEN NOT DRIVING IT).
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: My black car gets dirty so fast!
Having owned a few black Z28's I hear ya loud and clear! Here's a tip I got from a Mothers car care rep while I wash polishing my Z at a car show; "Ground it". Make up your own ground wire lead and a long screw driver or ground rod. Attach the gator clip end of your ground wire lead to the sub frame or chassis and drive the attached rod into the dirt. That will help reduce and discharge the static electricity on the body from attracting the dust particles that show up so well on our black beauty's.
Car: 86 Iroc-Z
Engine: 305 (TPI)
I keep two show vehicles parked in my (dusty) barn and the ground method helps. It's also really beneficial to add a quality car cover to the mix when they're not being used.
If you keep your car in a garage, you can try the same ground method by running a ground wire to and clamping it to a metalic water line or run your ground lead wire to the outside power meter ground rod. Lot's of options.. but still, Black highlights everything.
Good luck
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
all of the above , it's the nature of the beast/color . i have a dark blue/metallic color on my car . mine is a TRUE daily driver , i feel your pain . good luck .
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Its called "California duster". It will not fix your problem but its really nice when removing dust. You can pick them up at any auto parts store,Walmart,etc.There about $15.00. I don't have a black car but live next to a truck depo. and it really dose a nice job. Just give it a light dusting . Its advertised as safe for your car with no scratching. I have found that to be true.
Me too. I have an Altima coupe painted a color Nissan calls "super black." When the car is clean, it's wicked elegant--but that's short lived. Personally, I'd never buy another black car.
BTW, years ago I had some hesitation about using the California Duster; however, after seeing guys using them on paint jobs that cost more than my car, I purchased one. Glad I did. Recommended.
JamesC
JamesC
Hello guys,
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Transmission: Pro-built 700R4
That stuff is money! 'Been using in on my black GTA for seven years. Even had a local car detailer switch to it after using it on my car. Also, hit up your car with a clay bar before waxing/polishing your car. Your paint will feel like glass.
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
Iroc8t8
08-26-2015 08:14 AM
1992 Trans Am
08-08-2015 08:16 PM
