1989 IROC Camaro Hood Louvers/Blisters
Car: 1989 IROC Z-28 Hardtop
Hello All,
I searched the forum a bit and came up empty.
I have a stock hood 1989 IROC Camaro with the stock louvers. I would like to replace them with something else, blisters etc... and have a couple questions I was hoping someone could help me with:
Will the 91-92 hood blisters bolt on (into) the stock 1989 IROC hood depressions?
Anybody know of aftermarket options for the stock 1989 hood?
Thanks all for your help!
Corey
Whidbey Island, WA
Corey
Whidbey Island, WA
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: 1989 IROC Camaro Hood Louvers/Blisters
louvers and blister are interchangeable....only difference is louvers sit inside depression and blister sit over them.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I don't think they are interchangeable!
All the louvers I've seen, the depression in the hood starts smooth (flat) with the hhod at the front, and ends smooth with the hood at the rear.
BUT - the blisters do not end flat - they are deeper at the rear than they are at the front - all the ones I've seen were almost 1in deep at the rear - the louver hoods don't have any depression anywhere more than 1/2in that Ive seen. And thus the hood must have a different depression in it for a blister than a louver.
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
I thought they were interchangeable. Now you have me wondering. I would like to take the louvers off of mine and replace them with blisters then do a heritage style stripe. The louvers look a little too cheesie.
Transmission: wc T5
as far as swapping between louvers and blisters they are interchangeable, I've had both on my car (as have many other members)
*if the hood you have came with blisters or louvers ...you can use blisters or louvers ur choice
Car: 1992 RS
Engine: Carbed 350
No - not the early hoods - the later ones was what I meant.
Well, I wasn't for sure - I've never swapped them before to know. But just looking at them and their design, I would have guessed they would not swap.
And I hated to see anyone leap before they look, so I thought I'd play the devil's advocate here and post my thought that maybe they don't swap - good thing I didn't bet the farm! LOL
Thank you all for the information and pictures. It helped quite a bit...time to order some blisters!
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Axle/Gears: Posi
here is my car with the grills and blisters, the holes line up perfect! hope this helps you.Attachment 197869Attachment 197870
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
yes that is the daytona iroc hood but the holes are still in the same palce. the blisters and louvers are are interchangeable.
Car: 1986 IROC T-TOP
Transmission: 700-R4
Hey I live on Whidbey too. What are you gonna do with the louvers? Are they in good shape? I might be interested in buying them from you.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Axle/Gears: open rear, 3.42 gears
if y'alls louvers are in good shape, i would like a new pair.
mine are starting to really fade
pm me a price.
i personally like louvers better than blisters
pm me a price.
I have the same hood I believe. Iroc daytona hood from harwood. Anyways I bought the 85-90 hood louvers, I was hoping you help me with the location to drill the holes to mount them? Even the dimensions of the outside holes then I could figure out the rest.
If you don't know those numbers, do you know where I could get them?
sailtexas186548
Exterior Parts for Sale
02-29-2016 08:40 AM
mustangman65_79
08-11-2015 03:17 PM
