Shroud Decals
Car: 90 Camaro RS
Shroud Decals
Can someone show me close up pics of the center and right decals on the radiator shroud ? I have the one on the left, belt routing, but am missing the other two. Does anyone know where I can get these ? Tried all the usual places, even Osborn Graphics, where I got some other decals. If they have GM part numbers on them, that would be even more helpful.
Don't know if they are model specific but I have a 90RS 305.
I borrowed someone else's engine pic off this board ... hope they don't mind !
Re: Shroud Decals
I have been looking for the same thing!!! My decals were painted over and are all torn apart. It would really clean my engine bay up if I had brand new decals. If you happen to find this, please let me know!!! I am looking for the Catalyst and Belt Routing.
Car: 87 GTA
Re: Shroud Decals
http://ras001.0catch.com/stickers/stickers.html
I think if he doesn't already have what you need, he can make what you want, provided he can find a good clear picture of one to copy from.
Car: 90 Camaro RS
Re: Shroud Decals
Thanks Stephen ! Now we're getting somewhere.
He has the left and right stickers, what is the big one in the center ? What does it refer to ? Any part number ?
Thanks again for your help !
Car: 92 RS
Re: Shroud Decals
I read this thread the other day and kept it in the back of my mind. Today I took the cover off my 92 RS. (Starting to bring it out of hybernation) Anyway looking at the car from the front starting from left to right. The serpintine belt diagram, which I believe you already have. The middle one on my car looks just like the one in the pic and mine describes the airbag system and the basic wire diagram. The part number that is on the sticker is 10098508. The last one all the way to the right is a caution sticker warning you about the cooling fan starting without warning. The part number for that decal is 22016614. Haven't tried to look these part numbers up but Ihope they help the both of you.
Car: 90 Camaro RS
Re: Shroud Decals
Boom ! There it is !
I knew we would get help on this board. People here are some of the friendliest and most knowledgable folks I've ever met.
jimez1, thank you VERY much for that info, that was very nice of you. Exactly what I was looking for !
Now begins the search ...
Re: Shroud Decals
I e-mailed the guy Stephen suggested. He did not have the correct decals for my car. My decals are very worn down, but you can still see the belt routing anf the catalyst. I am going to be sending him some detailed pictures and lengths and he is going to make some reproductions. I would suggest finding a picture of these for your car and maybe having him do it. His prices seem reasonable.
Hope this helps.
Hope this helps.
Re: Shroud Decals
Classic Industries has most of the decals. I just got an emissions routing and another sticker from them.
Car: 90 Camaro RS
Re: Shroud Decals
Aaron R - Thanks for the info. I looked at their catalog last night. They do have a lot of decals, but not these.
Ibarile1991 - I still do not have pics, do you ?
Re: Shroud Decals
I will try to take some pictures of what I have today after work. I looked classic industries and the only decal I could find was the fan shroud caution decal, no catalyst or belt routing.
1 Post
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Shroud Decals
classic industries had the ones I don't have... I didn't buy any because I am doing an engine swap, so no point...
http://www.classicindustries.com/con...¤tPage=2
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Re: Shroud Decals
The fan decal is available from Jim Osborn Reproductions. I bought two for my GTAs and they are perfect. You may have to email about it as I didn't find them listed on the site but the part # is DT0867. The GM part number is: 22016614. Here is a link to their website:
http://www.osborn-reproduction.com/
Re: Shroud Decals
Just an update to this...The new part number is DC1425 for the fan shroud warning sticker. You will probably find the decal using the GM number 22016614.
Re: Shroud Decals
I received my sticker from Osborne reproductions. It's really good, but not exact. The pic below shows how they compare. I did trim the edges to round them like the factory sticker. I also trimmed the one side so that it is exact in size as the original. I don't believe anybody would notice the difference unless they are side by side.
Re: Shroud Decals
Mine is an ‘88 firebird w/ 5.0 E engine. [tbi] belt routing decal is gm#10055889. Hope this helps!
Axle/Gears: 10 Bolt 2.73 Open
Re: Shroud Decals
Is that the one on the black plastic radiator filler panel? I need that one too, but have never found them new or reproduced. If I could get a really good photo of one, I could probably get one made locally.
Re: Shroud Decals
Yes, that is the one! Mine is not too good! If you google that gm p/n you will find some good pictures of it. Black background with white lettering. If you want a shot of mine, i will b glad to send to your email address.
Re: Shroud Decals
Sorry, if you google g12827, you will see the one that classic industries did have. They say discontinued although the web site says ‘arriving soon’..... go figure
Re: Shroud Decals
You need to verify you rpo sticker for some reason I have found that the reproductions are for Cal. emissions cars. If you look at you rpo sticker get engine code trans code and emisions code then look at GM F ody Ref catalog under label it will give you the correct 3 digit code for your car. If you don't have catalog I can post a pic of page tonight when I get home
Re: Shroud Decals
Here is the first page. I will need to get the next page for you with 1988 info. Your car is not a Canada car is it?
Re: Shroud Decals
I would sure like you to post the correct pages for my ‘88! I know my emission label is o/n 10079601 and cmm code on upper left. Also would love to have the emission hose routing decal mine just says cmm also. No part number. Sure wish i had that catalog! Lol
Re: Shroud Decals
I will post. I just got catalog. I am in the process of documenting actual photos. It will take some time sorry but I started with 1986 fist since that is what I have. Hard to find people willing to take pics and send I am trying to verify with thier rpo code to make sure they are original and correct since reproduction are out their of some
Re: Shroud Decals
Here are the other pages
Re: Shroud Decals
Great! Sorry to bug you more but can you find the emission hose routing one for cmm code? No p/n on mine! And yes, mine takes the 10055889 belt routing and 10079601 emission decal! Thanks!
Re: Shroud Decals
I don't think they have them listed in this catalog. I am guessing that would be in a factory assembly manual. Not all labels are in the catalog
Re: Shroud Decals
Thanks randy! Classic industries has it p/n dt710. Cheap enough but the shipping is unreal! Guess that’s why the price is nice. Over $10 for something that could go in a .50 cent first class envelope! WTH? Gary.
Re: Shroud Decals
Re: Shroud Decals
Randy, when you have time can you lookup the p/n for the hood scoop? Says ‘5.0 liter f.i.. mine is silver 1988 formula. Thanks again, gary
Re: Shroud Decals
Randy, i think i found them! 10051986 right, 10051985 left! Wonder why they are different?
Re: Shroud Decals
I would think they have different part #'s so you could order a single replacement would be my guess.
Re: Shroud Decals
Just found 2 on eBay but a different p/n again! Call me confused.... this p/n is 10051949 and they call it silver, which is what i need! Glad u r patient w/ me! Lol
Re: Shroud Decals
Very interesting! Thanks for teaching me that! Sure wish i could find real gm ones.....it would be easier to locate them correctly, right?
codeysabatini
11-10-2015 04:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
