Jimbo's E36 Headlight Installation... maybe
Old 02-09-2010, 08:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As I said in Ramair21's E36 headlight thread, I wanted to make my own thread so that I don't bog his down with stuff.
Right now I'm still undecided whether I want to install these, mainly because I need to cut up the bumper cover to put them in, and so far I'm not convinced that I like their fitment. To put them in so that the lights will shine straight ahead, the glass has to be at too much of an angle for it to look right. If I put the glass at a more asthetically pleasing angle, my headlights will be crosseyed. I think this will be less of an issue once I start re-making half of the headlight assembly, which is going to be necessary anyway, since I'll be cutting away so much of the original assembly.
So anyway, here are some pictures so far. One thing I forgot to do was take some overall pictures of the full assembly. If I think of it, I'll do that next time I'm in the garage.
So, on with the pics:
This is what I'm starting with:
This is the backside of the headlight with the high-beam cap removed. You can also see that the low beam has the wires coming straight out the back of the housing because of the HID conversion:
The headlight is now upside-down, and I've removed the front piece which holds the outer lense, inner lense, angel eyes, and the black cosmetic piece that fills the area around the lenses:
Here's the backside again, with the low-beam cap removed so you can see the backside of the projector. You can also see the mess of wiring. Somewhat visible in the high-beam opening is the white box that holds the resistors for the LED angel eyes. This was just floating around inside. I'll need to find a better solution for that. A lot of this wiring will be cleaned up.
Here's the housing with the projector removed.
Here's the housing with the mounting panel (which still has the high beam reflector attached.
Here's the empty housing sitting in the headlight bucket on the car. The important thing to notice here is the alignment of the low beam hole and the hole in the radiator support. This housing needs to come down quite a bit for the two to be centered, which is what's necessary for the HID projector to fit without cutting the radiator support.
9 image limit. Continued in next post...
Jim85IROC's Avatar
Re: Jimbo's E36 Headlight Installation... maybe
continued...
Here's the glass (no housing behind it) sitting where I think it needs to be for proper headlight alignment, and also in as close to the original position as possible:
Same thing, but an overhead shot. You can clearly see that it sits real close to the radiator support, plus the angle of the glass is all wonky if I try to make the lights aim properly. This positioning looks dumb.
An overhead shot of the headlight re-positioned in a more asthetically pleasing location, as well as farther forward for radiator support clearance. This position angles the lights in, but I think that I can overcome that by re-positioning the steel plate behind the lenses that actually holds the projector/reflector so that I still get a straight shot with the lights on:
Front shot of the same position. The issue here is that the headlight isn't as wide as the opening, so I need to decide what to do about that. I'm not sure if a simple filler piece will be sufficient yet or not. Fortunately, my black headlight buckets will be more forgiving than somebody who has them painted body-color.
Angel eyes on. In real life, you can easily see the individual LEDs, which I don't like. If I keep the LEDs instead of going with CCFL, I'm going to need to come up with a way to diffuse the light more so you don't see the individual LEDs.
The next step is to start cutting up the headlight housings, but once I do that, I can't re-sell them, so I need to make sure that's what I want to do before I cut.
Old 02-09-2010, 08:57 AM
Awesome-X's Avatar
Car: 87 Camaro
Wow man that looks awesome. Can't wait to see what you do with it.
Old 02-09-2010, 09:22 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I love all these conversions you guys are doin. I wish someone could do this for me. I'm good at doin body work and paint (things I learn and practice in my collision repair class) I don't really know if I could do something like this myself. Maybe after one of you guys get done you can make a step by step thing so some of us less fabracating inclined people could do this. It looks rely good. Good luck completing it, I love it!
Old 02-09-2010, 10:25 AM
Jim85IROC's Avatar
I'll probably have a step-by-step account of what I did, but I can already tell that this is no beginner project. This is one of those things that you have to just dive into before you even know if you can do it or not.
Old 02-09-2010, 10:50 AM
Drew's Avatar
Received 1,054 Likes on 749 Posts
I can't say that I really like the look, but I'm sure when you're finished it'll look good.
Old 02-09-2010, 11:18 AM
Jim85IROC's Avatar
Drew, I didn't figure a guy like you would really like it... you and Stu are the two biggest "stock *****" I know. Of course, 99% of the time, I'm the same way. That's why I'm not sure if I really want to do this... I never really had many complaints about how the stock setup looks.
Old 02-09-2010, 11:28 AM
Drew's Avatar
It takes a certain amount of bravery to break from the norm. It'll be interesting to see how it looks when it's finished. I'm sure however you finish it will look good.
Old 02-09-2010, 11:49 AM
Grounded.4.Life's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L 350
Axle/Gears: Disc Posi
Keep us posted....Looks good. I want to see what you do with rad support/front brace for car structure. Will you have to cut just like he other guy did in the previous thread. That's why im interested. They look sweet but dont want to cut my support. Let us all know Jimmy.
Cheers and good luck. Again they look great.
Old 02-09-2010, 12:32 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
I don't understand why people want this mod!?!?
Old 02-09-2010, 12:45 PM
Car: 1989 Iroc-Z
Engine: 5.7L 350
It's a good thing then that's it not up to you TO understand.
Old 02-09-2010, 12:56 PM
Jim85IROC's Avatar
I'm not cutting the rad support. I'll abandon the project first. I'm going to attempt to modify the lights instead.
Old 02-09-2010, 12:59 PM
Car: 1989 Iroc-Z
Engine: 5.7L 350
Thats what i wanted to hear. I feel the same about cutting a non-frame car.
Keep me posted and really do hope it worked out.
Old 02-09-2010, 02:48 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Ill keep a good eye on this thread.
Tony.
Old 02-09-2010, 03:50 PM
ssean92's Avatar
Car: sold
Where you guys get these lights from?
Old 02-09-2010, 04:06 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
ebay :P
Old 02-09-2010, 06:23 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome work dude you have rad skills
Old 02-09-2010, 06:54 PM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
Very nice job bro keep it up!
Old 02-09-2010, 11:25 PM
AmorgetRS's Avatar
Not a fan of the round lights with how square the rest of a Thirdgen is. I am interested in seeing how it turns out, though.
Old 02-11-2010, 12:58 AM
Darbbackwords's Avatar
Car: 88 Iroc-z
Engine: 5.0 tpi
I really like the way these lights look in the pictures at least. That said I did some research on them and it seems its a fairly common mod for the BMW owners to retrofit new hid projectors into them. This is more of an investment obviously but is supposed to give them even better light output without blinding people, and might make it easier to re-aim the low beams at least.
here is a youtube series about the e36 headlights including HID upgrades: http://www.youtube.com/watch?v=gWGNM...eature=related
-It doesn't get very interesting until a little ways into part-4, which is where he talks about retrofitting HID projectors.
now after looking on HIDplanet, I have found you there so I will leave this for everybody else.
~Good luck, hope you go through with it as motivation for me once I get the funds
Old 02-11-2010, 04:24 AM
massaku's Avatar
Car: 84 15th anniversary Trans Am
Engine: 305 H.O. L69
Hey man I think those look really good! Alot of people called me crazy when I wanted to put "circle" headlights on a "box" car. Can you do me a favor and get some measurements on the lights? I may try to put something like this in my DeLorean someday.
Old 02-11-2010, 05:21 AM
KITT1983's Avatar
hey dude stop stocking me
the round lights would certainly bring out your Delorean
Old 02-13-2010, 12:48 AM
TGO - 10 Year Member
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thats the way it suppose to be done!
Personally though id use a better projector.Based on the other guys pic the beam was very disapointing.Not any better than the stock halogens & certainly not worth cutting the car up.
Old 02-15-2010, 01:52 PM
Jim85IROC's Avatar
I pulled the plug on the headlight project. I kept waffling back and forth, trying to convince myself that I liked it. If I had to work that hard to convince myself, then I obviously didn't. I finally came to my senses and realized that cutting up my car, along with a $400 set of headlights to get a look I wasn't even convinced that I liked was dumb.
I'm going to see if I can return the headlights, and if not I'm going to re sell them.
Anybody want to buy a set of headlights?
Old 02-15-2010, 08:38 PM
Engine: 3.0L 2JZGE
Just do what 84 1LE did to his headlights you might be pleased with that mod instead.
Tony.
Old 02-17-2010, 03:04 PM
Jim85IROC's Avatar
I'm not too keen on the appearance of projectors in the 4x6 housing. I think I'm going to stick some H4s into some clear housings and call it a day. Now I just need to try and recover the cash I wasted on buying these things.
Old 02-17-2010, 03:41 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
hey jim what do you think about the silverado conversion https://www.thirdgen.org/forums/memb...light-mod.html
Old 02-17-2010, 08:43 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
im pretty sure you can sale those things to some BMW guy. But like i said before you had to be committed to it from the beginning. Sorry it didnt work out bro!
Old 02-18-2010, 07:31 AM
Jim85IROC's Avatar
I don't like it at all.
Old 02-18-2010, 07:38 AM
Engine: 3.0L 2JZGE
To much cutting for me. I know I sounded like I really wanted to do this on the other thread but looking at it now not conviced. I mean they look great and everything but i'll just stick with the regular aftermaret ones.
Tony.
Old 02-18-2010, 11:53 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I didnt expect everyone to do this mod. Yeah it looks cool but there is a lot of cutting you have to do. I am working on making the core support more durable. Ive check the car the other day for any stress cracks. i could not find anything bad. but i do have an idea for the support ordeal. I love the look of my car now. i mostly did it just for looks since i dont drive the car everyday. i know some of you do drive your cars every day so this mod is worth looking at every direction to do this. I dont blame you.
Good luck to anyone that does this.
Joey J.
Old 02-18-2010, 06:53 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
With cutting and trimming those lights could look good. But I agree that if you have to amp yourself up to liking them, then you'd probably regret triming the core support to fit.
Wasn't there someone who put celebrity headlights in a camaro? Do they make those "diamond cut" headlights for celebrities? Could be easy to mount a real HID projector in a celebrity housing...
Old 05-11-2010, 10:25 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
niiiice im doing it too haha but im adding turn signal on the headlight
and im considering doing the red
Old 05-11-2010, 10:32 PM
WHITE88IROC's Avatar
Car: 88 IROC
Transmission: 4spd Auto
Thanks, Jim! You might have changed my mind on doing this mod! 5 mins ago I was all gung ho, then I read your thread...
Would you think that you could cut enough material off the light housing itself in order to aim the lights correctly, resulting in not removing the core support?
I'm not opposed to doing all the trimming to the lights...just not the car. The 4x6 halo lights are definitely a good looking alternate plan, tho!!! Thanks for the legwork Jim!
Old 05-12-2010, 11:25 PM
Zak.V's Avatar
Car: 92 players unraced
Engine: LB9
I was wondering if you placed the lights in as shown below but separated the glass from the housing and repositioned it as seen in the second picture. You would then have to make up an extension on the housing.
Maybe mock it up and snap a picture for fun...
Old 05-13-2010, 01:36 PM
Jim85IROC's Avatar
Yeah, I'm confident that you can trim away enough of the headlight housing to avoid cutting the core support. What you can't avoid cutting, is the headlight buckets, which is why I ultimately backed out of the project.
The only difficult aspect of this installation that I saw was fabbing up mounts to hold the lights in place. Making some mickey-mouse mounts from misc parts wouldn't be hard, but making it look like a nice clean, OEM installation would take some work.
That plastic is molded directly to the glass lense. You could remove it, but it would most likely leave battle scars. You'd have to make a whole new mounting scheme for the projector/reflector too... and if you're going to go that far, you might as well go a little farther and start from scratch and mold your own crap instead of playing with the existing stuff. If I ever decide to revisit this project, that's the approach that I'll most likely take. I'll start with flat glass lenses and mold my own lense housings from fiberglass. Ultimately it's the only way to make it look like it belongs there as far as I'm concerned.
Old 05-25-2010, 09:53 PM
juanillox8's Avatar
Car: TOO MANY
Old 06-05-2010, 02:25 PM
mikeoguz's Avatar
Car: 1991 Camaro RS
Engine: 350 Vortec carb
Transmission: t5
post some improvement
Old 07-10-2010, 11:56 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Watching this thread, I really like the look of these lights! Good work!
Old 07-11-2010, 01:27 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
lol..like how this thread got jackd? xD
Mikey
Old 09-02-2010, 08:04 AM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Jim is this still in the "scrapped project" bin??? How hard was it to remove the innards to the E36 headlights? I might have an idea that might work, but would still require quite a bit of fabrication with fiberglass and lexan/glass. I thought about removing the innards, getting them in place where you need them, still retaining their adjustment mechanics if possible, molding some fiberglass around them with mounting points into the fiberglass and then figuring something out for the glass part on the front if I still wasn't happy with the originals.
Old 09-09-2010, 01:51 PM
  #42
Jim85IROC's Avatar
For now it's still in the "scrapped" bin, but the euro-style H4 housings that I wound up installing are garbage, so I'm starting to rethink this to some extent.
The E36 headlights completely dis-assemble without much difficulty. The main issue with cutting up the lights is that you're going to need to re-design the headlight aiming mechanism because in it's current configuration, the threaded screws extend all the way to the back of the housing. Your idea is very similar to what I determined would be required to use these without cutting up the body, but ultimately I decided that it would still be necessary to cut up the urethane bumper in order to make room for the glass. Once I realized that, I more or less decided that if I do anything like this, I might as well just start from scratch.
Old 09-10-2010, 11:57 AM
  #43
mos68x's Avatar
Anyone happen to know the diameter of the light reflectors? just the part, making something to fit in that spot won't be a problem....as long as the lights themselves are small enough for i'm thinking of doing.
Old 11-08-2010, 02:25 PM
  #44
PaPaROC's Avatar
Car: 86 IROC
Engine: 305 carb
Transmission: 5 speed
Any more updates on this?
Old 11-08-2010, 02:44 PM
  #45
dans89's Avatar
Car: 85 z28
i saw ramair21's (i think thats his s/n) thread. and i was that he cut the core support. if you did it the way he did, couldnt you just simply box in the area that was cut to keep it rigid? BTW i am kinda new to fabbing stuff, so this was just a thought. by the looks of his pics, it looks like you could box it in with out an issue...
Old 03-15-2011, 02:45 PM
  #46
Cthornsmax92's Avatar
lets see some pictures of the aftermath on the radiator support, think this conversion is awesome. but so don't like cutting up a good rad support!
Old 03-28-2011, 10:36 AM
  #47
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I just bought the euro style e36 lights with CCFL angel eyes. I could easily modify the e36 housings to minimize any cutting of the core support. However, I don't know if cutting any material from the bottom of the hood is absolutely required?
Can anyone who's done this mod shed a little light?
Old 03-28-2011, 04:32 PM
  #48
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Has anyone installed these without cutting on the factory hood?
Old 03-31-2011, 03:16 PM
  #49
mikeoguz's Avatar
Car: 1991 Camaro RS
Transmission: t5
I DID HARLDLY ANY CUTTING!..my cousin made some brackets and it worked all well will post pics in a bit
Old 03-31-2011, 08:08 PM
  #50
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Please post pics! Top view of light housings with the hood up would be cool.
Quick Reply: Jimbo's E36 Headlight Installation... maybe
