Tinted Rear Tail-lights who's done it?
#102
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Re: Tinted Rear Tail-lights who's done it?
Going to have to call you out on this. How did you manage this with the tails being rippled? Any tips/hints/tricks would be truly appreciated. My tails are starting to look dull and I'm looking for that gloss tinted shine back.
Looks good. Can you still see the red through it in the day?
i painted them. I only used one coat of VHT then clear. They are
very glossy and the lights show up great in the day time.
P.S. these lights already appeared tinted from the factory!
#103
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Polish them before... got it.
My lights are also tinted from factory, but like I said they are looking a bit faded. I want them glossy tinted. I'll give 1 coat of VHT and clear a shot once bodywork commences.
Thanks!
If you can get a close up pic, that'd be cool.
Thanks!
#104
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
VHT Nightshade'd. Wipe tail light down with alcohol wipe, spray. let dry. Spray real clear coat, no rattle can, and be done. No polish or sanding or any of that.
Sorry for crappy quality. These were taken with my phone.
#106
Looks good. So the real clear, versus rattle can clear seems to have made the difference!
#109
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
Tried my hand with VHT Red and Niteshade. I am going to grab another set of tails and do just an amber delete/clearcoat on that set and change between this set I finished and that one based on my mood =P
Stock:
Taped off the grids to keep them black when applying VHT Red:
VHT Red amber delete results (no clearcoat on this, the next set will be like this with clear):
VHT Red, 2 coats VHT Niteshade (3 on reverse lights), and 4 coats of clear drying:
Finished product after 2000 grit wetsanding, Meguire's PlastX, and Meguire's Gold Class paste wax:
They came out a little darker than I wanted, but in the daylight you can easily see the amber delete and the colors in the tailight. That last picture makes them look really black. I would've liked 1 coat of Niteshade, but 1 coat does not cover enough - it speckles pretty badly. Overall though, I'm pleased
Stock:
#111
Car: 1991 Camaro RS
Transmission: Stalled 700R4
Axle/Gears: 3.23 Posi
I had the body shop paint mine with some over reduced black. What do you think?
Chris
Chris
#112
Engine: gone
Transmission: gone
Axle/Gears: gone
I like them. I really hate the amber on my taillights that is my main goal to eliminate the amber then i'll try and do a coat or two of nightshades and see how it looks
#114
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh yeah deffiantely will do the red first and see how I like them. That may be enough. The blacked out taillights would match my car but I dont like dealing with the cops on stuff like that
#115
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
The last set I did with VHT. I have a gun now, so it's probably going to be my last set rattlecanning.. but the end result isn't bad once you get the hang of it.
I did a complete writeup on exactly how to do this on one of the Thunderbird forums somewhere. I can dig it up if any of you need to look at it for step-by-step directions.
#120
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
I tinted mine with Niteshade. I removed the lens from the housing in sprayed them from the inside. They have been done for about ten years now. Easy maintenance, I just wax the lens each time I wax the car.
#121
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Had sometime this weekend and got some little projects out of the way... VHT + Clear
Rainy outside so sorry its dark
#124
#125
Axle/Gears: 9-bolt/3.45
Updated in reply #129
#128
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
I got covers, because I don't like them being permanent but the covers look flush and stock and really nice.Used VHT on my truck though, 4 coats and I cn see them perfectly
#129
The topic does say tinted, so that doesn't necessarily mean black. So I redded-out the amber sections.
First experimenting with a damaged set of Formula taillights, I tried "smoking" the lenses and then blacking them out, and I didn't like how either looked.
So with a good set of taillights and Nite Shades Red, I "redded" and clearcoated only the amber sections(leaving the rest of the lenses as natural plastic), and I worked only on the outside of the lenses. They came out transparent, smooth, glossy and very natural-looking.
Then with a simple wiring mod to the base 'bird taillight harness, allowing you to change the turn signals into turn/tail lights(as outlined in the linked thread), then moving them up to the red sections, these taillights can be made to work similarly to TA taillights. It's an alternative to swapping to TA taillights.
https://www.thirdgen.org/forums/auto...ula-trans.html
And for the record, redding-out the amber lense on the inside doesn't work(unless you're blacking-out the entire lense); I opened-up a damaged taillight and tried this. The amber lense is thick, so from the outside it still looks very amber.
#130
Car: 1989 Pontiac Firebird Formula
Engine: V8 5.0 305 TBI
Transmission: 700R4 with B&M MegaShifter
Axle/Gears: Gear Ratio: 2.73 Ring Gear: 7 5/8
#131
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Lots of people do it, few do it right.
I am not saying I do it right per say but its better than slapping the rattle can VHT on some non prepped. Not knocking VHT nightshades, its a good product and I have used it. There are better ways though.
Wet sand the lights w 800 grit. Clean with wax/grease remover. Apply adhesion promoter. I use sikkens clear/ jet black mixed to a certain ratio. Even coat to desired darkness. One heavy coat of sikkens clear over top. I use my sharpe detail gun 1.0mm tip. You can use other brands of course but this is what I use.
#132
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
I used VHT. sorry for little darker image. but can see the lenses are blacked out with the reverse cleared out.
#133
I happen to think that looks good. I like it. Different.
Mine aren't blacked...but are tinted. Thinking about going a shade darker...
#134
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
thanks. Try to be alittle different. They are glossy too cause I wet sanded them when I was finished and cleared them.
(side note.. what springs are on you car I like the stance?) (nevermind seen your sig. lol.) intrax
#135
They are a true 2in drop. They drive nice, not horribly stiff, the few corvettes Ive driven where worse on the road bounce.
I paired them with the kybgr2 shocks and I love it! Car handles like its half its size.
#139
Car: 1992 RS vert
Engine: forged 383
I want to spray mine but when i dId my bumper lenses with VHT, my newer lamp came out perfect and my older one was cracked and spider webbing..anyone ever get this?
#140
Car: 1985 Iroc-z
Engine: Stock 305 lb9
Axle/Gears: Really dont know
When i did mine im not sure witch one i used cuz i have them both the rust-oleum and the vht one of them faded away in like 4 months and im pretty sure it was the rust-oleum one cuz i did my parking lights,side markers and my foglights and they look darker then my taillights when i did them
#141
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
I have had the webbing cracks in the front turn lamps, I sanded them out completely then went with lighter and lighter sand paper. Once that was done then I blacked them out with great success.
#142
Car: 1992 RS vert
Engine: forged 383
What grits did you use?
Even then im afraid of doing it on my tails. I did them
On my brand new Tahoe tail lights with perfect success. I dont want to be sanding and sanding and sanding my tails
#143
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
um.. If I remember correctly I used like 1000 grit, then worked way up to wet sanding with like 3000. IIRC
#145
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
2 coats of tint on the amber lenses only... The full black out didn't flow well with my car.
http://www.flickr.com/photos/53106660@N03/7292445268/
#150
Car: '91 TA vert
Engine: turboLSx
I think they look best when tinted/sanded/polished. Dull tail lights really kill the backend of the car.
