Which One Of These Camaro Grilles Will Fit?
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Hello everyone,
I would like to change the grille on my 1990 camaro i have the louvered style grille and I would like to change it. So Id like to get one of these in the attached image. Which One will bolt up like a direct fit and where are the mounting screws located? and how would I get to them. Also with this new grille where should i mount my license plate as i dont want to cover the bowtie or camaro.
Car: 1984 Z28 camaro
Engine: 388 ci stroker
Axle/Gears: 3:73
Re: Which One Of These Camaro Grilles Will Fit?
i like the chevy emblem better my self and it would match your car so
Car: 92 RS
Either grille will fit. The holes are the same as with the louvered grille. Unfortunatly, the plate holder will cover the bowtie or the camaro wording. Unless you get a plate holder that will mount to the bumper cover next to the turn signal. But I think that looks tacky and you will need to drill holes for that application. I have the bowtie grille and my plate covers the image.
Axle/Gears: 3:73
yeah i wouldnt move the plate holder but maybe get rid of it
1 Post
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
The bowtie is nice , but if your state is very strict with front mounted plates!and the idea of drilling holes else were in the bumber is something that makes you wanna m, I say it don't matter, remove the old grill and your done same look! considering if you get the new grille the plate will cover the emblem anyway...
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There is a difference in mounting between those and the louvered ones. The louvered ones have mounting hols in the top and bottom, the ones you have pictured have mounting holes in the top, as well as inside the inner edges of the foglight holes - no mounting holes in the bottom.
I installed the "CAMARO" one on my 1992 RS, but there isn't much holding it on until I come up with something better than drilling more holes in my brand new nose cone!
Car: 1985 IROC-Z28
Engine: 305 HO (L69)
Transmission: Rebuilt T5 (updated T5 parts)
The grille insert on the bottom,put the ugly front license plate in the passenger side of the windshield. It's what I did.
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
