custom gauge project!
Old 11-14-2009 | 03:14 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
hey guys here is a new little project im working on, its a new gauge cluster for my autometer gauges, its not finished yet, I still need to finish fiber glassing it, cut holes & paint it, then install the gauges, the gauges are tilted upwards so i can see them better, they are also out a lot father than the originals as you can see in the pics, i wanted something different so thats why im making my own, i will post more pics as i go,hope you like!
Old 11-15-2009 | 10:43 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Re: custom gauge project!
here are a few more, do anyone like it? or have any suggestions.
Old 11-15-2009 | 11:52 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I like it! What is the surround gonna look like, painted black or.....? Gonna have a way for dash (SES & such) lights to show?
Old 11-15-2009 | 08:24 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
its going black, im going to try and incorporate all the lights as well.
Old 11-15-2009 | 08:30 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
four thumbs up! i need to do this as well!
what about oil psi and volts?
curious to see the speedo and odo
Old 11-15-2009 | 11:36 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
thanks man! Im waiting for my speedo and volts gauge to show up, here is where the volts,water and oil will be going.
Old 11-15-2009 | 11:46 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
thats sweet. ill have to take a picture of the secret panel that a p.o made in my car for the old cd changer controls. i plan on taking those out and putting a oil pressure and volt guage there. noone will ever know when the door is closed. ill get you a pic tomorrow.
Old 11-16-2009 | 12:18 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Looks like it will turn out really well!
Old 11-16-2009 | 02:23 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
well my speedo showed up, so here is the last two pics till i get it painted.
Old 11-18-2009 | 05:42 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
well here it is painted, still needs to be clear coated, but im really happy with the way it turned out,i need to make a wiring harness for it yet, make sure it all works and then i will install it, to bad i don't have my engine yet lol, hope you like!
Old 11-18-2009 | 08:26 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Attachment 188787Attachment 188788
Did you use bondo by any chance?
Tony.
Old 11-18-2009 | 08:27 AM
poofy95's Avatar
Car: '86 Z28
Engine: LSX swap in progress...
Axle/Gears: 3.48
That's amazing. I'm going to try something like that with my camaro once I get to the interior. Amazing work.
Old 11-18-2009 | 08:18 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
yes i used some bondo, but the main part is fleece stretched over the shape, and then fiberglass resin brushed over it and wait for it to harden. any more info i can give let me know, thanks for the comments.
Old 11-18-2009 | 09:51 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Only four thumbs up! i beat you and give it five thumbs up. LoL Btw great looking setup gives it a racey look to it.
Old 11-18-2009 | 09:53 PM
82blackout350's Avatar
Car: 1982 Camaro
Transmission: saginaw 4spd manual
had to subscribe! thinkin bout doin somethin like that, looks great!!
Old 05-01-2010 | 09:44 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
well guys im finally started my wiring harness! i don't have much time to do anything with work on the go.what do you guys think of the way i have this hooked up? I'm thinking that this way i can dim the lights from my head light switch, if this works out i wont have to cut my harness on the car,all the grounds,ignition and some senders are already there,the one on the right will power the volts,clock and air fuel, the one on the left will get ran to the pillar pod powering the oil pressure,temp and water temp, gas spedo and tach will finish up the rest of this set up,if you have any info please let me know, i'm not sure if this will work so any info will help. custom gauge project!-dscn1974.jpg
Old 05-02-2010 | 10:06 PM
nezzie09's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
wow.. this is sick.. might try that with my 87 Camaro
good job!
Old 05-02-2010 | 10:08 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Great job! Looks totally awesome.
Have any more pics of your car? It looks pretty damned good from what I can see in these pics.
Old 05-09-2010 | 02:45 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
OK guys here are another few pics, I'm almost finished you can see what I'm doing here, the way i have the wires hooked up works really good, its a pretty simple set up, i had them all lighted up just to see if it worked, and it worked fine, i still don't have a motor in the car so i cant see if all the senders work, but i think it will be fine! I still have to hook up the other 3 gauges ill be putting them under the heater vents, you can see where i have the wires ran out, would like to know what you think, good or bad, hope you like!!
custom gauge project!-dscn1990.jpgcustom gauge project!-dscn1994.jpg custom gauge project!-dscn1998.jpg
Old 05-11-2010 | 05:10 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
looks great
Old 05-11-2010 | 05:18 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
well guys im finally started my wiring harness! i don't have much time to do anything with work on the go.what do you guys think of the way i have this hooked up? I'm thinking that this way i can dim the lights from my head light switch, if this works out i wont have to cut my harness on the car,all the grounds,ignition and some senders are already there,the one on the right will power the volts,clock and air fuel, the one on the left will get ran to the pillar pod powering the oil pressure,temp and water temp, gas spedo and tach will finish up the rest of this set up,if you have any info please let me know, i'm not sure if this will work so any info will help. Attachment 198156
For the wiring I would use a quick disconnect on them like this one. It is what I used on my custom guage cluster and makes life extremely easy when you need to remove them from the car.
http://www.summitracing.com/parts/PRF-40012/
Looks good though
Old 05-11-2010 | 05:26 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Awesome looking!!!!!!
Old 02-15-2011 | 06:07 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
thanks for all the comments guys!
Old 02-24-2011 | 01:48 AM
LT1_IROCZ_KID's Avatar
Car: 1987 IROCZ
Engine: LT1/4 hybrid
Axle/Gears: Posi
wow that is awesome!!! I have a similar set up planned for my car I have the exact same gauges as well! I'm going to do my cluster panel out of carbon fiber though, and have oil pressure in the center and the fuel level, water temp, and volts under my center air vents hehe
Old 02-25-2011 | 09:32 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Looks good though
you can buy these connectors at radioshack for a few $.
Old 03-28-2011 | 04:52 PM
Demon355's Avatar
I have the same gauges and wanted to run the same setup you made. Same with the gauges under the vents. I don't like the pillar mounted gauges so wanted something different, you beat me to it
Any finished pics with them under the vents?
Old 03-31-2011 | 10:35 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
i like the gauges under the vents to, everyone has an idea that someone already had on this site, i think that there are so many creative people on her, i have had ideas that i didn't think people already used, but then you find it here, but that only gives us an opportunity to improve on that idea, i have so many ideas that i want to try but i need another car to try it with lol.
Old 04-19-2011 | 11:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
here is a few pics of mine.
Old 05-23-2012 | 08:47 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
love the gauges under the hood!
Old 06-02-2012 | 11:10 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
hey guys my gauge project is almost finished, but I hit a wall, can someone tell me if I need to hook up only two wires to my volt gauge, or can I use the red/sender-white/ignition-black/ground from my orignal cluster? autometer instructions say its a two wire hook up, can someone confirm this for me, here are a few pics, thanks
[ATTACH][ATTACH]custom gauge project!-dscn46412.jpg[/ATTACH][/ATTACH]
Attached Thumbnails custom gauge project!-052-2.jpg   custom gauge project!-dscn46402.jpg
Old 06-03-2012 | 11:39 AM
BOTTLEDZ28's Avatar
Transmission: A4
The voltage meter requires 2 wires. One is ground and the other is a 12v switched ignition wire. If you can use the that supplied a signal to the OEM gauge then use it. If not then find you need to run a wire from the gauge to the fuse panel that only gets 12v when the key is turned to the run position. Look in your fuse panel and locate a spare terminal that says IGN. That will be the place to tap into for the "feed" wire for the gauge. Use a test light to verify that the location on the fuse block is only hot when the key is in run. If the test light lights up with the key in the OFF position then that is a constant power terminal. Do NOT use those spots.
Now it's been a while since I played with these gauges but the last time I checked, Auto Meter had a seperated white and black wire going to the light bulb socket. You can either splice the white (hot) wire into the same wire you are using to feed the gauge or you can tap into one of the gauge cluster wires that does to the headlight switch. The later option will turn the gauge light on when you turn your headlights on.
Old 03-10-2013 | 12:35 AM
!CamaroDave's Avatar
Car: 87 Camaro IROC, 85 IROC Roadste
Engine: 5.7 V8 350 TPI, 383 - Coming Soon
Transmission: 700R4, Turbo 350
Dang! Nice build! Im gonna end up doing something like this with my Camaro. Keep up the good work!
morrow
01-13-2024 01:29 PM
Jorlain
10-08-2015 02:57 AM
UltRoadWarrior9
09-02-2015 09:24 PM
Hotrodboba400
09-02-2015 08:28 PM
Quick Reply: custom gauge project!
