Buying New Air Compressor. 80 or 60 gal?
Old 08-29-2009 | 01:08 PM
Dogfrost9's Avatar
Car: 1984 Camaro
Transmission: 350 Turbo
Iv been looking around for a new air compressor, we currently have a 20 Gal Husky with 1.5 horse, When i try to Spray a car or even worse, sand blast some rust It does not keep up at all. I dont do a ton of sandblasting or spraying but Id like a compressor that can handle both easily. Will a 60 Gal compressor with 5 - 6 hp do just fine or should I spend the extra 300 or so to get an 80 gal? Im having a hard time deciding.
Old 08-29-2009 | 01:31 PM
cwj108's Avatar
Car: 1991 Z28
Engine: 305 (for now)
Re: Buying New Air Compressor. 80 or 60 gal?
I had this same question last week and talked to a guy about it. Im looking at purchasing one too and he said one thing to look at with your compressor keeping up with your tools is the cfm. A lot of tools use around 9 or a little less cubic feet per minute so the higher cfm rating, the fewer problems you will have with your compressor keeping up. I was only looking at hp and gal size and knew nothing about cfm (im new to the whole compressor thing as you can tell). I hope this helps.
Old 08-29-2009 | 11:36 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have the husky 60 gal. I use the everloving dog snot out of it and it does fine. It runs constant with my DA sander, but for the rest of it, it is no problem.
Old 08-30-2009 | 12:42 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
yup, it's all about the CFM, CFM, and CFM, which all has to do with the pump. They could put a large pump on a 20 gal tank and it would still out perfom a larger tank with a smaller pump. At least after the first time the pump kicks in.
Old 08-30-2009 | 07:06 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
true, but if you know you have a small pump, getting a big tank will act like a bandaid.
if you were me, you'd get the biggest tank you can afford or have space for, whichever comes first lol...
that being said, if you have the choice between bigger compressor and bigger tank for about the same $$$, get the bigger compressor.
Old 08-30-2009 | 07:19 AM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
No matter what you choose a bigger tank will help. you need to look at the compressor. what cfm recovery it has at 90 psi. Also hp. single stage or two stage. If you can afford a two stage that is the way to go.
Old 08-31-2009 | 04:48 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
CFM, CFM, CFM
If you're buying a new one, get the CFM rating you need.
Then if their is a choice, go with the bigger tank.
And if you really beat the
dog snot
out of it
go one step larger. It's taken me a LONG time to mentally
accept this, but stop trying to cheap on tools that you use
a lot. If it takes longer to budget the greater expense, just do it.
In the long run, it WILL be worth it.
Old 08-31-2009 | 07:32 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
there is a phrase that comes to mind
if you cant afford to do it right the first time, can you afford to do it twice
something like that at least
Scamo-2.8
05-20-2016 07:01 PM
Wylecoyote08
11-06-2015 03:46 PM
Bubbajones_ya
08-28-2015 02:17 AM
rh76camaro
08-15-2015 12:48 PM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: Buying New Air Compressor. 80 or 60 gal?
