Hot Rod Magazine Concept Body Kits
#51
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Hot Rod Magazine Concept Body Kits
I think the consensis is that the term "SBC" is of the original design of the engine that started back in 1955 and went through either 1998 or 1999... What I found interesting is the Gen II is referred to on the Vortec engines of the 96-98 era, but for some reason there was some major changes in the block of the 1987 engine, with the single piece rear main seal than the 96 block... There was some head design upgrades, but AFAIK, or until proven wrong, I thought the block itself on a Vortec was essentially the same as the 87-95...
I do know from talking to truck owners, that a 1996 5.0L will outperform a 1995 5.7L...
John
John
#52
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The Vortec from 96 - 98 or 99 was in that same class of Gen II AFAIK... I am not sure about the LT1, I would expect that yes it was but not sure...
John
John
#54
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
The vortec GEN I 350 continued in Van duty for a while after 99 also.
ambainb
04-25-2016 09:21 PM
xbmx89
South Central Region
10-31-2015 10:59 AM
