painting my dual snorkle air cleaner
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
so my dual snorkle air cleaner looks like crap and i want to repaint it. im going to scrape/sand down all the rust and then primer it with rustolium. my question is can i use regular black spray paint or will the heat from the engine bake it off? would a high temp paint be better? and should i seal it or will the paint by itself be ok? thanks for the info.
heres a pic of my air cleaner/ engine. i know, it doest look that great but ive cleaned it up the best i could since and it looks a little better.
1 Post
Car: 92 Z-28
Transmission: THM700R4
Re: painting my dual snorkle air cleaner
Did the same thing to my single. Put a wire brush in the end of a drill, got all rust off, washed all dust off, then primed it, them painted it with heat paint. If all you have is regular paint, give it a try, you will probably be OK, if not, then later you can touch up the spots with heat paint. Where is your ducting for the Air cleaner? Whole motor looks like it could use a bath. Must live in dusty area.
I used krylon plastic fusion, semi-gloss black paint on my plastic a/c box and its still excellent a year later. No primer, just cleaned it, maybe sanded it, and painted it. I'm surprised it held up to the engine bay heat. I've sprayed krylon plastic fusion without primer on polished plastic at 30 degree temperatures and it stuck to the plastic with no issues.
Car: 87 trans am
Engine: 305 tpi
Transmission: auto unfortunately
I just used regular rustoleum when i did mine on my tbi truck holdin out good for about a year now.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the key factor to any paint job is proper prep. work . you can get good results with a rattle can . clean , proper prime , clean , & paint light coats till you get what you want . most major brands of paint are o.k. , i find it best to use same brand primer & final paint . stay away from dollar store stuff . good luck .
1 Post
Car: 92 Z-28
Will look good, but you may be able to find one aftermarket cheaper than having yours chromed. New decals a great idea.
its was sitting in a garage for a couple of years so it probably gathered dust in there + it was porbably never cleaned. i cleaned it up and its much better now. im still going to wash it with some degreaser though.
also, is there an online store that sells new 5.0 Liter H.O. decals? I see then on ebay occasinally but thats about it.
1 Post
Car: 92 Z-28
I think all the resto stores sell them like Classic, Eklers, YearOne. Ebay may be a good alternative, though.
1 Post
Car: 1990
Axle/Gears: stock
and do the same with the black paint, except you can get down to super fine steel wool. it will look like glass.
1 Post
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
High heat is a caliper and manifold type purpose paint. Regular can (no matter how cheap) is fine for everything else. I don't suggest painting anything like tubing or porous materials that flex. I wish I had a dual snorkel to put on my 305 but im not paying the ebay price when most of them are rotted and rusted. I'm gonna be painting my snorkel soon. Anyone have a direct link to breather decals?
Try Ebay for new one
http://www.ebay.com/itm/82-92-Camaro...de9e20&vxp=mtr
http://www.ebay.com/itm/83-86-CAMARO...fbfecb&vxp=mtr
Greg
Greg
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Sand blast that one. As long as the rust damage isn't too severe it should clean up to look brand new. I bought one from a junkyard for 13 bucks and sandblasted it myself and I'm having it E-coated black again its gonna look nice
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
a can of wd-40 and some cheapo 99 cent rags form autozone work wonders, you can use wd40 on anything and it wont hurt it, clean up all your hoses and vacuum lines, get one of the fingernail brushes to scrub things like the acc brackets, the firewall and anything else that will have road grime or oil (lets be honest they all leak a bit) on it, if your as ocd as i am jack it up get underneath and scrub the oil pan and the block and manifolds too, its important to keep using a clean brush or rags though, else your just pushing dirt around
86IROC112
09-07-2015 01:37 PM
BurlyChev
08-22-2015 01:52 PM
