3rd gen under hood Pics post them here!
Car: 91 Bird
Engine: Pontiac 500 + CID
Transmission: 3 speed auto
I am looking to make my Frirebird look better under the hood...and want some ideas! With a big Alu rad what are you guys using to hold them in?
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: 3rd gen under hood Pics post them here!
Here's mine. I have fabricated chrome valve covers for it once I get a vacuum pump.
1986BANDIT (03-15-2021)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Far from stock. Just brute force HP and cosmetics isn't an issue.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Here's my 355 I just installed about 3 weeks ago. It's ALOT more fun than the LO3.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
newest pic of my junk
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: round ones "3.73"
Not the best pic but gets the point across. You dont need nothin special to put a big radiator in. These cars come stock with big radiators so ones like my 4 core B cool fit right in.
Blue Beast...electric blue pearl coat?
1 Post
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Thank you. The paint is off a 95 Corvette. Every time I chased one down to ask what color that was they all looked at me like I was crazy and said blue. I finally got it figured out, not to bad for a 13 year old paint job. I know pretty doesn't make you go fast but why not do both.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Got lots to do yet. I do have a new coolant tank to put in once its back from paint.
Car: 92 Z03 RS TBI
Engine: 5.0 L03
If you're just trying to make it look good and a little flashier,
Gutting all the emissions crap is a good idea (if you haven't already), AC Delete if its a track car. Wire looms are always nice, and some nice valve covers. Other than that it's just wire management and paint.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Few months old post, but:
Old setup:
Newer setup:
Newest setup:
Old setup:
Newer setup:
Newest setup:
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I just wanted to state if we are going to have threads like this we need to keep the pictures forever hosted in this thread. Some of you have posted and gone back and deleted the picture from this thread. Please update your posts again with the picture. This is what makes it hard to keep TGO clean is because people make threads like this, then people post pictures for 3 days then remove them, so when people come in here all the pictures end up being deleted or no longer hosted, so another thread ends up getting started. Thanks guys.
Some nice bays on here.
Is that a KRC overflow tank. They are about $130 and I want one, but not sure if I want to spend the $130 on basically a box of sheetmetal. Let me know more about that tank.
but it bolts right in, has a threaded connection for the overflow hose so you can use AN line if you want, it looks better than stock, and you dont have to cut anything
i really need a new pic of the engine bay, quite a few things have changed
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
SinisterZ
Mine - The lesss there is.. the neater it is
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Car: 91 RS
Engine: Carb'd 350
Transmission: built 700R4
Car: 91 Z28 Coupe
Engine: 5.0 TPI
Yea, I did it myself. Sanded it down starting at 400 grit and ending at 1000 grit. Then I took it to a buffing wheel using Tripoli, and finished using white rouge on a wheel.
Car: 1980 Malibu
Engine: 496 BBC (E85)
Transmission: TH400 w/brake
Axle/Gears: Moser 12 bolt 4.10
Here's mine (need to smooth & paint)
1 Post
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I'm in the middle of working on mine to get it up and right... I've stripped the plenum and polished it and took off the serp brackets and polished them... but where do you guys get those individual wire looms for the center bolt... ? I need to pick me up some red ones.. this is the old pic.. sorry I dont have the newest one but I'll post it prob sunday
1 Post
Car: 1991 Z28
Engine: 355 TPI
so far this is what I got as of yesterday.... still got a lot more to do but you can see where I'm heading... Haven't even touched the wiring yet or the coolant lines but i'm getting there
1986 Z28 tpi smog and a/c stuff GONE
Hey guys. I yanked ALL the smog and A/C stuff off my engine and installed a new Weiand aluminum hi-output water pump, new radiator, and 195 T-stat with the torq flo standalone cooling fan switch. I don't need EITHER the smog or A/C up here in Wyoming. I said, "Screw the delete pulleys, as well." I don't see the point of those. I plugged the smog holes in the stock manifolds using little screw in black pipe plugs.
I did a new cap and rotor, new Accel Ferro Spiral wires, and NGK Iridiums. I still have to paint and install my headers--Hedman shorties-and new Hedman Y-pipe. As you can see, I haven't given the engine bay a good washing yet...it needs it. It's a tired 305, but it runs pretty strong. Oh, and the car used to be blue...ha.
#42
1 Post
Car: 1991 Z28
Engine: 355 TPI
Re: 1986 Z28 tpi smog and a/c stuff GONE
man while you had all that off you should've cleaned the front of the motor and repainted parts that needed it or replaced them. Like the timing chain cover and the front of the heads.. just my opinion...
#44
Engine: 305TPI
the car was sittin out in oregons weather with no protection for 5yrs and the engine was never washed until a couple months ago but theres still some dirt and pine needles and crap like that but doesnt look to bad for about a good 2hours total of washing and 10 hours of polishin. also the only products for polishin has been well rags and meguirs alminum polish and mothers aluminum polish no sandpaper used here and this all has been done by hand not machine. competly stock.
#48
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i should have pictures coming soon, just had engine bay painted and motor is sitting as a rebuilt shortblock.
Its a white engine bay with an all black motor, top of the stealth ram, valve covers and timing cover are all polished. Got my accessory brackets sand blasted and going to paint them an aluminum colour. a/c and smog pump deleted. got a few clean up issues to figure out but it should look pretty good pretty soon.
#49
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Holy cow! you can see the color of the coolant and wiper fluid. I can't even see the level of mine on the outside. Thats so sweet, I got to get new once.
#50
Car: 1990 Camaro
Engine: 355ci
so why is it that no one is using something like this tucked away beside the rad? i think this looks pretty slick.
Would actually love to get rid of the washer fluid tank as well if there were a way
