Projector retrofit inside(w/pics)
Old 06-13-2010, 10:52 PM
  #101
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
Re: Projector retrofit inside(w/pics)
any cars that may pop in a junkyard that i could rob HID's to fit in these?
Old 06-14-2010, 04:33 AM
  #102
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
look for hondas or any japanese car with stickers
Old 06-14-2010, 05:55 PM
  #103
Stephen's Avatar
Car: 87 GTA
Or most modern BMW/Mercedes/any car/etc...HIDs aren't just a r i c e thing....Its a modern car thing. Stickers have nothing to do with OEM HIDs.
Old 06-14-2010, 07:29 PM
  #104
KITT1983's Avatar
yeah but the HIDs on a german cars wont fit our cars. they are DR1 and DR2s. they are specially built for the german/japanese cars.
Old 06-14-2010, 07:42 PM
  #105
Stephen's Avatar
Car: 87 GTA
Why would that be a problem, other than wiring & adapting?
I already know of at least 1 3rd gen Camaro already running DS2s & 2 'birds being worked on to be fit with DS2s, which are used in applications from BMW, Mercedes, Range Rover, Lamborghini and Audi.
Old 06-14-2010, 08:10 PM
  #106
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
My projectors are D1S & i just recently built a set for a member with the same projectors, but with D2S lamps.D1S/D2S style are the best bang for the buck.
As for the JY most, if not all late model projectors are pulled by employees or early birds.Dont hold your breath on finding TSX/Valeo/Hella or any other popular projector.Try ebay or hidplanet.
  #107
KITT1983's Avatar
ok this is getting off topic
thats not what the 19Chevrolet84 asked for? I asummed he meant plug and play Hids not ones needing modding of the headlight harness
Old 06-14-2010, 08:36 PM
  #108
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Dont think he meant plug & play.He asked what car to look for at the JY.Any car you get projectors from, whether at the junkyard or not will not be P&P.
The cars to look at are BMW, Mercedes,Jag,Audi,Infinity,Lexus,Acura.Also vettes,cadillac STS/escalade.There's more, all late model.Like 04-up, but again good luck finding them at the JY.
Try to keep them under 3inch dia lense.
Old 06-15-2010, 10:17 AM
  #109
Stephen's Avatar
Car: 87 GTA
I mean modding, as in a PLUG & PLAY wiring adapters.
EVERY HID retrofit will require "modding" whether it is a plug & play mod...Or a cut & splice mod. The only 100% plug in "HIDs" are just that.....FAKE HIDs.
If anyone wants to retrofit a TRUE HID into a sealed beam vehicle? It requires some sort of "mod". No way around that.
Old 06-15-2010, 04:37 PM
  #110
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I got my fleabay housing in today and already cut them open. The 3" projector fits, but I had to grind off a small bit of the metal lip of the projector lens housing. No biggie though.
Old 06-15-2010, 06:12 PM
  #111
KITT1983's Avatar
now this is really getting off topic the guy was asking about what cars to get hids off of in a junkyard not what is the right to install HIDS
lets continue this in pm
Old 06-17-2010, 10:49 AM
  #112
Engine: Rebuilt 350
Axle/Gears: Stock
84 1LE thank you for that helpful information, hopefully i can rob a set pretty cheap and do the retrofit like you did.
Old 06-17-2010, 10:59 AM
  #113
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Your welcome.
Old 06-17-2010, 11:04 AM
  #114
Stephen's Avatar
Car: 87 GTA
How much & what all is there? Just the housing & the E55?
Old 06-17-2010, 11:14 AM
  #115
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Its a Valeo projector, e55 is bi-xenon & too big.Compltete kit is $285 or just the housings/projectors is $195 (buy your own HIDs)
The HID kit i have is ddm 35w Raptor ballast,D2S 4500k or 5000k lamps,harness & D2S adapters.
Plus shipping or pick up if local.You will need to enlarge the hole in the bucket as i did, but no other cutting required
Old 06-17-2010, 11:23 AM
  #116
Stephen's Avatar
Car: 87 GTA
So this is a Lo-Beam only setup? Not like the Hi/Low E55 you were working on for 'birds?
I live too far out of town to give up my High Beam headlights.
Old 06-17-2010, 01:56 PM
  #117
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
FBs have hi/lo in one headlight, seperate on camaros.I dont see the point in rearranging the stock set-up.So FBs get bi-xenon, camaros dont.No need to give up hi beams either, still fully functional.
If someone wants HID hi beams.Then another HID kit is required for camaros.Siverstars work well in the hi beam, thats what i have.
Old 06-17-2010, 02:19 PM
  #118
Stephen's Avatar
Car: 87 GTA
Originally Posted by 84 1LE
FBs have hi/lo in one headlight, seperate on camaros.I dont see the point in rearranging the stock set-up.So FBs get bi-xenon, camaros dont.Not need to give up hi beams either, still fully functional.
If someone wants HID hi beams.Then another HID kit is required for camaros, not my taste.Siverstars work well in the hi beam, thats what i have.
So these for Camaros? What size? We both know the82-90 Firebirds have a different size than t 91/92 'birds. I thought you had E55s in your Camaro, even though you still have 4 headlights.
Old 06-17-2010, 08:37 PM
  #119
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
"So these? what size?" not understanding! Did you edit a pic or something?
Never tried E55 since they are bi-xenon.I have a set of Valeos that are too big at 3in(Vs 2.5 on my car).So i knew the E55 would be too big also.
My hi-beams function as original, just have a Osram(silverstar) lamp inplace.Never use them anymore though.
I know of a 2.5 bi-xenon projector that should work in both types of FB lamps, but its $150+ for the little buggers.Dont think many would buy my FB retrofit if i used them.Thats about double what i pay for the Valeos.
Old 06-17-2010, 08:41 PM
  #120
Stephen's Avatar
Car: 87 GTA
"So these? what size?" not understanding! Did you edit a pic or something?.......
I meant the ones you advertised for sale here in this thread. They are for Camaros?
Old 06-17-2010, 08:46 PM
  #121
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, those are for camaros, still working on the FB set-up.Even if those would fit the later FBs.They are still single xenon, not bi xenon.
Old 06-18-2010, 10:08 PM
  #122
Engine: Rebuilt 350
Axle/Gears: Stock
I probably read over it... I'm notorious for doing so...but is that 275$ a ready to go set of lights?
Old 06-19-2010, 12:26 AM
  #123
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, ready to go, plus shipping if you cant pick up.You will need to enlarge the hole in the bucket as i did, but no other cutting required.
Old 06-19-2010, 05:51 AM
  #124
KITT1983's Avatar
Did a little upgrade on mine.So they stand out a bit from the rest.Sorry, halos & shrounds are not included with the retrofit.Gonna do the hi-beams too.
once again you did some radical work
Old 06-19-2010, 08:34 PM
  #125
92purplehaze's Avatar
Car: 90 IROC-Z
Transmission: M6
Axle/Gears: 9" spooled 3.70
https://www.thirdgen.org/forums/sout...check-out.html heres some pics of the retro fit 841le did for me. How easy was it to install the halos? I was thinking of adding city lights to make the buckets glow
Old 06-19-2010, 11:32 PM
  #126
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Halos were easy, but i had to trim the shroud alot.Almost half the size now.You dont have the little hole for the city lights anymore.It was cut away for the projectors.
Old 06-27-2010, 10:42 PM
  #127
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
very cool
Old 06-27-2010, 11:34 PM
  #128
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
What kind of bulb do these take?
Old 06-28-2010, 11:47 AM
  #129
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The retrofits i make use D2S, but my car has D1S lamps.
Old 06-28-2010, 06:31 PM
  #130
TheMuskr's Avatar
PM'd
Old 06-29-2010, 09:54 PM
  #131
TheMuskr's Avatar
Just bought his projectors. cant wait to get them!
Old 06-30-2010, 12:57 PM
  #132
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Shipped them this morning via fedex, enjoy.
Old 06-30-2010, 08:20 PM
  #133
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Very interested in a complete set. (the 4 headlights). Id love a price with and without halos. spikeiroc@hotmail.com. Thanks, and again, very cool craftmanship.
Old 06-30-2010, 11:26 PM
  #134
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
There is no 4 headlight set.Only 2 (lo beams) for the complete kit.No plans for shrouds or halos either at the present time.My current set up is pushing $400 just for parts.
Old 07-03-2010, 05:02 PM
  #135
AndrewD5418's Avatar
Have you thought about using the Morimoto for Bi-xenon, and putting it as close to the glass as possible maybe quarter inch away from it? I would be really interested if you could make a set for me like that, as they would be going on a talon that I have.
Morimoto's only cost 135 for the set and use an H1 bulb. You probably already know all this but here's all it's specs.
Max Depth: 136mm (5.35" inches) Max Height: 70mm (2.75 inches) Max Width: 80mm (3.14 inches) Lens Diameter: 2.5 inches
If not who is the seller of the "projector" housings you're buying from? Ebay seller?
Old 07-03-2010, 08:32 PM
  #136
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not for the camaros, but thats the exact same projector i wanna try retrofitting on the firebirds.The way i mount the Valeo, puts lenses at about 1/16 apart from one another.
I dont know what kind of headlamp talons use.So i cant say if i can make you a set.Plus unless the talon uses a single headlamp for both hi/lo beam.I dont really see the point in retrofitting a bi-xenon as opposed to a single xenon, but thats your choice.
At $135 plus though.Its not something Im gonna be doing anytime soon to see if they'll work for your talon.However if your willing to buy whatever headlamps you need for the talon.Plus those miromoto units.Ill be more than willing to give it a shot.You'll still have to pay for labor, of course.
I buy my "projectors" from ebay seller cyber-speed2008.Sorry i could'nt be of more help to you.
Old 07-04-2010, 12:52 AM
  #137
The generation of the Talon I'm talking about getting it done for are the 90-91. It uses the dual filament sealed from factory but a lot of people switch over to H4 housings. The Talons, Eclipse, and Lazers for those years use the same 4x6 housings.
Old 07-04-2010, 01:08 PM
  #138
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Well if your willling to make the investment in parts.Ill do the work.Should find out how much room you have before buying those projectors.
Almost done with my little upgrade.
Old 07-10-2010, 09:43 PM
  #139
Alomost done with my little upgrade.
Just looked behind them. I should have enough clearance, if not I could cut away at it back there since it's not structural there. It'll be a couple of weeks to come up with the funding since I have some stuff to fix on the car, but I will be willing to. How much would you charge for the labor?
Old 07-10-2010, 10:48 PM
  #140
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
PM sent.
Old 07-12-2010, 08:00 PM
  #141
TheMuskr's Avatar
Heres some pics so far
Almost completely installed
Attached Thumbnails Projector retrofit inside(w/pics)-imag0019.jpg   Projector retrofit inside(w/pics)-imag0026.jpg   Projector retrofit inside(w/pics)-imag0020.jpg
Old 07-13-2010, 09:34 AM
  #142
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not a bad cutoff.How far from the wall?What HID kit/harness you using?
Old 07-13-2010, 07:13 PM
  #143
TheMuskr's Avatar
The cut off is one light with the car parked maybe 15 20 feet back with ebay hid kit. i forgot what site i got my harness though
Old 09-27-2010, 04:42 PM
  #144
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Sorry to be a thread necro, but do you have any shots of how you got the halos in?
Old 09-28-2010, 12:54 PM
  #145
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No, i dont, sorry.
Old 09-28-2010, 02:28 PM
  #146
Car: 1989 Camaro RS
Engine: LH6
No, i dont, sorry.
No worries. Would you mind explaining how you did? I'd like to copy your set-up for my Camaro, I like how it looks, and the increase in visibility is awesome.
Old 09-28-2010, 08:45 PM
  #147
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
They're held on with double sided tape.
Old 09-28-2010, 11:36 PM
  #148
Car: 1989 Camaro RS
Engine: LH6
Ah, so just stick the tape to the back of the halo, and stick it around the projector. Thanks a lot!
Old 09-29-2010, 12:34 PM
  #149
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yep, thats it.
Old 09-29-2010, 01:49 PM
  #150
Car: 1989 Camaro RS
Engine: LH6
Thanks for cleaning it up man.
Quick Reply: Projector retrofit inside(w/pics)
