Stripped and Refinished Stock Formula Rims/Wheels. What do ya'll think?
So this is the stock rim with the outer lip restored. (Sorry forgot to take one before.).
Pic of car before paint---
This is after I stripped them and repainted them...
So the process was as follows:
1. I masked off the inner lip where the rim meets the lip.
2. Used Aircraft Stripper and applied heavily all the way around the rim. (BTW Use Gloves. It is similar to acid. The burning through the fingers part. Learned that the hard way.
3. Used super fine steel wool (0000) to remove stock clearcoat.
3.a. Repeated Step 2 if needed.
4. USE A TOOTHBRUSH to get in the small areas.
5. Wipe off with a paper towel. Or many.
6. Spray down with water.
7. And i Used EAGLE One Never Dull which works wonders on any dull or faded metal.
Paint Stage...
1. Mask off finished lip.
2. Paint it.*
*It is a helluva lot easier to paint in the holes in you stand the wheel up and paint through the back.
Color is Metallic Black. But you cant see the metallic in the pics.
So what do you guys think?
Paint Stage...
2. Paint it.*
Car: 88 Formula
Engine: E code, what else is there ??
Transmission: 700R4 stock
Axle/Gears: Stock w/ limited slip
Re: Stripped and Refinished Stock Formula Rims/Wheels. What do ya'll think?
That looks sharp as hell no lie...I hate that clearcoat GJ =)
Car: 89 formula 350
Engine: 402 CI ls2 with tvs1900
Transmission: t56
looks real nice.. although I think it would look better with center caps painted black also.
JMO..
JMO..
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Did mine, same way, absolutely love it!
(After and Before)
(After and Before)
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looks great
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Mine will be next I am thinking. Ill post pictures when I finish them. I think I am going to try and polish mine...
theshackle
03-05-2017 06:37 PM
