Headlight Covers
1 Post
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Headlight Covers
After reading some older posts I came across that somebody on here makes clear headlight covers? I know most people say they fly off but I am interested in the ones where people have them screwed in.
Car: 73 Camaro
Engine: 355
Transmission: TH350
Axle/Gears: 3.23 posi
Re: Headlight Covers
I am also looking for clear ones. Nobody seems to be making them anymore, because all I find are smoked ones. Wade and GTS have been around a long time, but don't make clear ones anymore for some reason.
1 Post
Car: 1987 IROC
Engine: 350 Gm H.O
My brother got the smoked ones and he has to take them off when he drives at night. Quite annoying. I was lead to these ones on summitracing which I think I am going to order if nobody really replies to this thread.
http://store.summitracing.com/partde...rt=GTS-GT0110C
Scroll down to the bottom of the thread to see what they look like.
https://www.thirdgen.org/forums/body...ht-covers.html
1 Post
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
heres mine. (never mind the hood and cowl, i was just taking some progress pics. hoods getting painted soon so dont flame me!) im pretty happy with them and yes it is VERY annoying having to take them off at night. its not terribly annoying, but it does kinda get aggravating. as you can see in my 2nd picture i went ahead and screwed them into the headlight pocket like you mentioned. the green circle is just the little tabs that they come with. the one with the blue circle is just some metal i made so it wouldnt slip out from the bottom. they hold in very well when the hoods on. i just slide the covers on and they hold on nicely.
bought mine on ebay for 10 bucks. somebody had some silver overspray paint on it. took the buffing wheel and some rubbing compound to it and it came out beautifully
1 Post
Car: 1987 IROC
Engine: 350 Gm H.O
Your car looks like one nice ride. Cool engine bay. The smoked headlight covers are really cool. Maybe I should just replace my headlights with KC 100 watts to shine through the covers at night. lol I'll take a look at pwdbychevy. Thanks
Car: 92 RS Camaro Red RED LEATHER!
Engine: 305 Stock with chip
Transmission: Automatic
Axle/Gears: Stock
I have headlight covers too and was thinking about painting them red to match my car. I think it would look like a mix between a TA and camaro.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>The original Pace car had clear headlight covers....anybody know how they were fastened?
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
anything above 45 and they,ll fly right off.. also you have to double sided tape those plastic brackets on..
I've got a set that I have never touched (clear and black I believe) mainly because I have seen my hood louvers go "batmobile" on me flying off , yet their were no machine guns under them unfortunately. This is a solution waiting to happen. Something that will successfully keep the clear light covers in place.
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
I made my own covers. Only for show, but they rock, I think. You can see pics and instructions here:
https://www.thirdgen.org/forums/afte...eadlights.html
The original export covers had 3 holes drilled into the leading edge of the headlight bucket. The covers had 3 posts that had a notch in them. They were installed by holding the cover perpendicular to the ground, insert into the drilled holes, tilt back towards the headlights locking the notched posts. The fiberglass headlight frame had 3 sleeves attached to it. The top of the cover had 3 plastic tabs that slid into the sleeves and locked in with the plastic fasteners that hold the wheel well liners in place. When the hood was closed, the covers were inaccessible. Very quick and easy to remove for cleaning and won't fly off at speed. Unfortunately, there will be 3 holes in the front bumper cover on each side.
