A few media blasting and powder coating questions.
Old 03-21-2009 | 04:25 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I just got a media blaster and a powder coating system from harbor freight and I don't know if I am using it right. I bought glass media 80 grit and used the smallest nozzle. I am trying to clean a tpi intake, but I nearly used 15 lbs of media to clean one runner and it's not even done.
How big of a nozzle should I use? What type of media is best to use?
Also I want to powder coat this stuff when I am done. Would an old oven work for this? I was thinking about wiring up a 220 socket and putting an old oven in my garage.
Thanks!
Attached Thumbnails A few media blasting and powder coating questions.-img_0091.jpg   A few media blasting and powder coating questions.-img_0092.jpg   A few media blasting and powder coating questions.-img_0093.jpg
Old 03-21-2009 | 11:28 PM
86transam.man's Avatar
Car: 1986 Firebird Project
Engine: 3.1L
Transmission: t5
Re: A few media blasting and powder coating questions.
First of all I am new to this forum so if I did anything wrong please just point it out.
I use a blasting cabinet with just generic bead in it, an Eastwood powder coating system, and an old retired kitchen oven. I would suggest that you use Gumout Carb and Choke cleaner and a clean rag to clean it before you powdercoat it, and if the part is extra dirty or is porous I would recommend you prebake the part because it gives the powder a better finish. The only problem with a house hold oven is size, I have often wanted a bigger oven to do things like transmission cases. Just my
Old 03-23-2009 | 03:36 PM
Abubaca's Avatar
Car: 2016 Camaro SS + ???
My buddy has an old household oven in the garage that we've done TONS of powdercoating in.
We use acetone to wipe everything down as a final cleaning before coating.
Old 03-24-2009 | 01:26 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
YOW... Yeah, something's wrong. I'm not a *-blasting expert, so I don't know exactly what it is, but I'd strongly suspect that it's the media that you're using. Take a look at the pic below:
Here we have one good ol' Aussie 9-bolt, pretty much "in the buff":
I did that (the whole thing) with somewhere around 10-15 lbs of sand. Try using different nozzles if you have some, but I'm guessing that the media that you're using is just too "soft" & that you might want to step up to something else.
Old 03-25-2009 | 12:18 AM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
go to lowes and get a few bags of play sand and try that, thats what i used to use on aluminum, on heavy applications i go to tractor supply co and get there stuff called black beauty. that stuff works great
Hotrodboba400
12-10-2019 08:07 PM
RyanJB
Members Firebirds
39
11-20-2018 04:30 PM
87v6Bird
Brakes
10-04-2015 08:37 AM
rudolphschenker
09-04-2015 03:41 AM
Hotrodboba400
09-02-2015 08:28 PM
