Safe way to remove existing glossy armor all off dash?
Does anyone know a safe way to remove the shiny armor all off the dash, is soap and water ok? I want to start over fresh using a low-gloss protectant that won't reflect in the windshield as badly as the regular armor all, plus I like the low-gloss look better, looks classier and newer.
Car: 82 camaro SC
Simple green will clean it up.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
