Odd question, but what color would powder coat your transmission?
Old 10-19-2008 | 09:38 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I just picked up my T56, and Im wanting to tear it down and upgrade it a little. So in the meantime, I was thinking about powder coating the case and bellhousing. I did my T5 in Xtreme Chrome which turned out pretty nice, but what about doing like a candy blue over the chrome? I was originally going to do it either in the Xtreme Chrome, or just do it black. I know this is OCD to the max, but Im curious what yall would want yours to be if you had the option.
Here's the powder over polished aluminum, basically the same reflectiveness as the chrome powder:
http://roseyspowdercoating.biz/osCom...products_id=86
And here's a pic of my engine bay. I haven't painted the car yet, but I went ahead and painted the bay so you can get an idea of how close the color matching would be.
Attached Thumbnails Odd question, but what color would powder coat your transmission?-sany0192a.jpg
Old 10-21-2008 | 09:44 PM
spills's Avatar
Car: 89 RS
Re: Odd question, but what color would powder coat your transmission?
ahh come on, I know some of yall have thought about more than a few times
Old 10-22-2008 | 12:35 AM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
Yeah, I am kind of OCD about stuff like that too. Just a couple of months ago, I had a bad wheel bearing on my truck, and the project of changing that turned into going ahead and replacing the one on the other side also, replacing all of the seals on that axle, changing the fluid, taking a wire wheel to every chassis component, the entire frame, brake calipers, drive shaft, etc. (front to back) and painting everything underneath there.
But, to the original question, I have actually thought to myself before that if I ever did have transmission problems, and had to pull it, that I would paint it with the Dupli-Color Aluminum colored engine paint before I put it back in. So, if I were to powder coat it, I would probably also go with an aluminum looking color.
Old 10-22-2008 | 09:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
chevy orange
Old 10-22-2008 | 09:22 PM
spills's Avatar
Car: 89 RS
I pulled the guts out of my T56, so I should be able to start sand blasting it tomorrow or sometime next week. Then Im at least going to lay down the chrome powder and go from there. Not sure if I want to do the candy blue, might be too much. But the chrome looked killer on my T5
Old 10-22-2008 | 09:28 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I think chrome would look pretty good, do you have any pic's with the t-5 in?
Old 10-22-2008 | 10:07 PM
spills's Avatar
Car: 89 RS
no, I never got that far About 2 weeks after I coated it, we were replacing the 3-4 synchro and in the process broke the 1-2. So I dont have any install pics, but Im supposed to be getting the T5 back from my trans guy tomorrow.
The T5 though doesn't look like chrome though, because I was trying out a clear coat powder and it dulled the hell out of it. It looks more like a bright semi-polished aluminum, but no where near what it was before the clear. Ill try and get pics of the T5 with clear and the T56 with just the chrome so you can see the difference.
Old 10-22-2008 | 11:34 PM
spills's Avatar
Car: 89 RS
OCD, and because I have the means, the materials, the time, the patience, and I want every part of the car to have a certain touch to it. I already had to pull the trans apart to inspect it, I still have 2lbs of chrome powder laying around, I just finished converting a double oven into a single oven, and Im not sinking a few hundred dollars into rebuilding it only to throw it all back together inside an oxidized and nasty looking case.
It's just like when you rebuild a motor, alot of people will paint the block. Honestly, you usually cannot see the block especially if you still have the AIR, HVAC, and all that other crap still installed. But it's still nice to know that if someone does see it, it's not just "there", it's "there", but they will definitely take notice.
Plus I'd love to take the car to the exhaust shop or whatever and have them say "damn, nice looking trans, who did that?" Give em my business card and possibly get some new clients
Old 10-23-2008 | 03:37 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Aluminum, or if they make a cast aluminum powder go with that.
Old 10-23-2008 | 06:34 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Black or aluminum.
Old 10-31-2008 | 08:50 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My car is red. I painted the case and extension housing red and the front plate black when I rebuilt it awhile ago.
Only real picture I have of it.
Old 11-18-2008 | 12:42 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I would say black or chrome. On a side not the piece you made to cover the area around the hood latch looks really good. Any chance to see a picture of it if you ever remove it, what material and how did you mount it I don't see any screws around the edge like is a stock piece.
Old 11-18-2008 | 12:47 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Ive seen one in Black, and it looks BAD ***! I vote black... I dont havea pic of it, cuz i only saw it online for sale. It looks good with all the silver lines you have goin to it.
Also, paint the bell housing the same colour as your engine. Whatever that happens to be.
Old 11-18-2008 | 02:16 AM
spills's Avatar
Car: 89 RS
I'm still fooling around with that. I'm working on cutting out some lettering, it's just on the back burner right now. If you look closely, you can see the screws that hold it in place. On the front part near the nose of the car, I reused the original mounting holes. Then I just got some sheet metal screws and put one near the striker to avoid anything getting tangled when shutting the hood, and I put about 4-5 I think on the top on the core support. I basically just used some poster board to make the template and transfered it to some sheet metal I had laying around. I'll try and get some more pics for ya if ya like, but it's nowhere finished yet.
I dont have any shiny lines going to mine, it's a T56 For me though, black is too dull. The undercoat on the car is black, so I want it to stand out against that, I just cant decide between the chrome powder alone or with a candy blue topcoat. But ya, I've seen some TH400 and 700R4's coated in black at car shows, and it does look damn nice.
Old 11-22-2008 | 11:08 PM
spills's Avatar
Car: 89 RS
Got mine done today. For now Im using Rosey's Xtreme Chrome. Turned out pretty nice, tell me what ya think.
The bellhousing has only been sandblasted. You can really see the before and after in the pic.
Attached Thumbnails Odd question, but what color would powder coat your transmission?-sany0215.jpg   Odd question, but what color would powder coat your transmission?-sany0213.jpg   Odd question, but what color would powder coat your transmission?-sany0220.jpg
Old 11-22-2008 | 11:09 PM
spills's Avatar
Car: 89 RS
close up of the bellhousing and main case, man she's puuurrdy!
Attached Thumbnails Odd question, but what color would powder coat your transmission?-sany0216.jpg
Old 11-23-2008 | 08:00 AM
Car: 2012 Corvette
Engine: LS3
That really looks good, it's not nearly as reflective as I'd imagined it would be. That looks like polished aluminium.
Old 11-23-2008 | 11:15 AM
WIll36's Avatar
Engine: 355, 408
Looks sick. I'm going to have to settle for just painting mine since it's already been rebuilt. Wish I had time to powered coat it before hand.
LT1Formula
08-20-2015 10:36 PM
redmaroz
08-17-2015 12:40 AM
Feffman
Mid-West Region
08-13-2015 08:12 AM
Feffman
08-13-2015 08:11 AM
Quick Reply: Odd question, but what color would powder coat your transmission?
